Turn on then turned off, does it have a power fuse?
  • 528 Answers
You are having a problem probably with your VGA signal, not with the monitor. Connect your PC to another monitor and check. If it works, go to display settings, reduce the screen resolution and click OK. Shut down the computer, reconnect your monitor, and boot the PC. Now OK?
Posted on Jul 13, 2009
I have a 2001 gmc Sierra 2500hd. There's no power going to the trailer fuses under the hood. Do i need to change a relay or something?
look at other lamp fuses, sometimes an seemingly unrelated fuse will be the power source for your non powered fuses.
Sep 20, 2017 | GMC Cars & Trucks
I TURN KEY POWER CUTS OUT CLOSE HOOD HARD POWER RESTORES TURN KEY POWER CUTS OFF . TAP FUSE BOX POWER RESTORES TURN KEY POWER CUTS OUT. WHATS GOING ON I CHECKED WIRES AND CONNECTIONS IM LOST
Apart from the obvious electrical connections, you could try checking each fuse. Sometimes they appear to be ok but 1 end of the fuse may be broken and touches intermittently. Try lightly tapping each fuse 1 at a time with the handle of a screwdriver and see if anything goes on and off.
Mar 21, 2017 | Cars & Trucks
Rear lights not working on 2002 suzuki grand vitara
In the underdash fuse/relay box, the 15A TAIL fuse feeds power to the coil of headlight relay 2. When the combination switch is set to TAIL, the relay closes and the outer tail lamps light. In the same underdash fuse/relay box, the 20A STOP fuse feeds power to the brake light switch. When the brake pedal is pressed, the inner brake lamps light. The underdash fuse/relay box also contains the 10A TURN BACK fuse which feeds power to the hazard switch and the turn signal relay. Relay output is fed to the combination switch and turn signal power is applied to the selected middle tail light. The fourth fuse in the underdash fuse/relay box is the 15A HAZARD fuse which feeds power to the hazard switch and turn signal relay. When the hazard switch is set, the turn lamps on both sides begin flashing.
Sep 18, 2012 | 2002 Suzuki Grand Vitara
Security light comes on and engine will not turn over
find fuse for the security system under hood if remote or switch does not turn it off pull this fuse out light should be out on dash when u find the right one then open door turn ignition switch on not crank just power on then replace security fuse then try to crank if dont work pull fuse again and the main 50 amp fuse that sends power to everything turn switch on leave door open replace fuses in proper places and then crank
Sep 06, 2012 | 2005 Chevrolet Impala
Iv got an 88 F150 4x4 iv got turn signals light fuse is good got power at break switch need no break lights and is there suppost 2 b 1 r 2 wires coming out of fuse box
Do you have power at both sides of the brake switch when the brake is applied? If so it sounds like the turn signal switch is bad. try turning on and off the 4 ways a few times. sometimes this will clean the connections and it will start working.
The power goes through the fuse to the brake switch. from the brake switch to the turn signal switch from the turn signal switch to the tail lights. If the 4 ways are on the power goes through the 4 way fuse to the 4 way flashers then to both sides.
If the turn signal is on and the brake is on, the turn switch cansles the power from the brake and uses power from a 3 fuse and flasher for the side that the turn signal is called for.
If I typed to fast let me know. I can answer any questions you might have.
If this helped you please vote 4 thumbs up. :-)
good Luck and God Bless
Jun 07, 2011 | 1988 Ford F 150
Location of the turning signal fuse
GET A GOOD FUSE TESTER, TEST EVERY FUSE. 2 BOXES ONE UNDER THE HOOD & ONE INSIDE THE VEHICLE. THE FUSES HAVE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE POWER ON BOTH SIDES GOOD FUSE, POWER ON NEITHER SIDE, SPARE FUSE.IF THE FUSES TEST OK, YOU MAY HAVE A BAD FLASHER, OR BAD TURN SIGNAL { COMBINATION } SWITCH.
Jan 06, 2011 | Daewoo Lanos Cars & Trucks
Trun signal wont work
First check the turn signal fuses.The turn signal fuse is fuse number 8 in fuse box.If the fuse checks out ok then the next thing to check would be the Turn Signal Flasher Unit. Power flows from the fuse to the flasher and then to the T/S switch. You should have power to the dark blue wire at the flasher. If you do then check for power at the purple wire at the T/S switch connector. If you have power there, then you have a bad switch. If not, then you have a bad T/S flasher unit or an open in the power side of the circuit.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | 1991 Chevrolet Lumina
Looking for fuse box on 1998 ford windstar
Fuse panel is located behind the instrument panel to the left of the steering column. There is also a fuse panel located on the left side of the engine compartment. Fuses #25 and #27 on the interior fuse panel are both associated with the turn signals.
I hope this helps you!
Apr 10, 2010 | 1998 Ford Windstar
6632lg hdtv won't turn on
No stanby LED would indicate a power supply problem. check the main fuse and the 4 large diodes next to the fuse. one is common to short out and blow the fuse. i think D603
Hope this helps
Jun 29, 2008 | Sylvania Televison & Video
Sharp TV
It could be a blown fuse, sometimes when power is restored a power spike occurs this can blow fuses in appliances. Check power to either side of main fuse. Then progressivly check all other minor fuses Cheers Paul
Sep 17, 2007 | Sharp 27H-S200 TV
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
