Question about Microsoft Windows Vista Ultimate Edition
No audio out put device is installed
I have built in speakers on my lab top but for some reason it says that there is no audio output device is installed how do i fix my speakers
    President:
  • 778 Answers
You need to install the correct audio driver for your Vista lap top. The make and model of the laptop would make it easy for us to point you directly to them via a link.
You can verify your audio device is configured or not in "Device Manager".
Posted on Jul 13, 2009
3250hd
How have you connected the audio cables to the TV? The 3250HD has component, DVI, and composite video out. There is also two analog audio outputs (for the component and composite video) and a digital audio output. Make sure that you are using a TV and not a monitor. Many monitors do not have built-in speakers. (In that case, use external speakers.)
If you use the digital audio output, make sure that your audio receiver audio input is connected to the set top box audio out. Then make sure to set the correct source for that audio signal. (Note the TV may have a digital audio port; that is an audio out.)
If you are using one of the analog audio outputs directly to the TV, make sure that you are using the correct set of audio IN on the TV and audio out on the set top box. (If you are on the Component input, your audio won't be heard if you are using the Composite audio output.)
Next try different audio cables. Make sure that the TV speakers are on. (Some TVs have an option to disable the speakers if you use external speakers at times.) Try connecting the audio output to a receiver and speaker system (or speakers with aux in). You might need an RCA F/F to 3.5 mm M adapter for some devices. If another set of speakers do not work, then the set-top box probably has a broken audio output. If another set of speakers work, then the problem is with the TV audio. This could be a problem with the jack or the speakers.
I hope this helps.
May 02, 2013 | Black Box Computers & Internet
I have a acer with the acer crystal eye webcam built in it. do it have a microphone with it. if so how do I get it to work?
The Acer with crystal eye webcam will also have a built-in microphone. The webcam is in the center at the top of the screen. The built-in microphone is typically half-way between the edge of the screen and the webcam. It is a little opening with a microphone logo beside it. You can test both audio input with the built-in microphone and the audio output with the built-in speakers by doing the following....
1. click start > Control Panel > Sounds and Audio Devices
2. in the Sounds and Audio Devices Properties click the Voice tab, then click the Test hardware button
3. in the Sound Hardware Test Wizard window click the Next button, if required, click unblock...
4. speak into microphone to do the Microphone Test. Recording meter will show movement if it works.
5. click Next button to do the Speaker Test. Microphone input is now output on the speakers.
6. click Next button when finished doing the readings and click Finish to close the wizard.
Mar 20, 2011 | Computers & Internet
Yar i have formatted my pc and i have installed driver but no osund is comimng in headies and 5 speakers?
did you set it up under your sound device's in the control panel may need to set default sound device so it knows what to be using for a sound device this happens some times. for output to speakers it needs to be set to the speakers as default you should see you audio card and any other output hw
Jul 01, 2010 | Creative Labs Sound Blaster Live! 5.1...
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Distorted sound after installing software plus GigaPocket issues
Have you physically disabled the onboard sound in the BIOS? By doing this I think most of your other hardware/software would default to the only audio device (your SB).
Post back if you've already done this and I'll see what else I can dig up on your hardware and possible conflicts.
Mar 03, 2009 | Creative Labs Computers & Internet
No Windows Media Player Audio from Surround channels
On WMP - go to Tools > Options > Devices > Select Speakers > click Properties > Audio Device to Use - ensure you select your audio Card (Not direct sound - just a precaution) > Advanced > Volume Tab > Speaker settings click on Advanced > Select the type of Speakers you have. - Hope this helps, let me know!
Oct 28, 2008 | Creative Labs Audigy 4 Sound Card
Speakers not working
do i need a disk to dwnload these to work on my computer
Aug 09, 2008 | Boston Acoustics BA735 Computer Speakers
No sound is coming out of my HP vs 19
it sounds like a problem with your sound card driver. Try re-installing it.
Feb 09, 2007 | HP vs19 (Silver) 19" LCD Monitor
Microsoft Windows Vista Ultimate Edition Logo
154 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
