By paulrmc - usenet poster
That is the AI meter coupling ring. If it is sticking, it needs to be
serviced. It should track the aperture control smoothly and evenly so
the meter is informed of the set aperture.
Godfrey
Best Solution
posted on Aug 04, 2005
Mini Me - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I had this problem with an FE2. That ring is your metering ring. If that
ring is sticking, YES your exposures would be affected.
A service by your friendly camera repairperson is needed.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Ranny - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Your description of the AI ring and the pin (tab) is correct. What alarmed
me is that you mentioned that the ring is not in contact with the lens. In
Nikon FE, the tab can be flipped up so that you can mount non AI lenses on
the camera. If you mount an AI lens on the FE with the tab in the up position,
the ring will not be in contact with the lens. The little button on the ring
locks and releases the tab.
In article , writes:
I have a Nikon FE. There is a ring with a small metal pin just around
the outside of the bayonet mount. The pin on this ring comes into contact
with a ridge on the outside of the bayonet mount of the lens, so when you
move the aperture ring on the lens it moves this ring on the outside of the
camera bayonet mount.
My problem is that sometimes the ring on the camera bayonet mount sticks
in place when I move the lens aperture ring counterclockwise. I am worried
that my exposure meter is not reading the right light reading when the ring
is not in contact with the lens. Everything seems to work okay anyway, but I
am not sure. I am wondering if the ring is only for older Nikon lens, to
link to the exposure meter in the FE.
If anyone knows anything about this ring and its function I would
appreciate any information.
Joanne
Shu-Hon Yu Internet: s @mayo.edu
2D-336 SMH Voice: (507) 255-6664
Mayo Foundation, Rochester, MN 55905 FAX: (507) 255-5484
Joanne
Solution #3
Duke - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Joanne
Joanne
Suggest a new solution for this problem
Post a New problem for Nikon FE 35mm SLR Camera
Email this problem
Email this problem
Can you Help with these Film Cameras problems?
Frame Counter Indicator does...
Hi my wonderful FE works well... Answer This...
FRame Counter does not move...
My Wonderful FE works well but... Answer This...
nikon FE shutter speeds problem
My Nikon FE (with batteries)... Answer This...
Nikon FE- Winder return...
I have Nikon Fe - 1983 model .... Answer This...
Repair Service
Find Film Camera Repairman Near You:
