Question about Whirlpool Dishwashers
ADP 4305. Where can I obtain a service manual?
Does not filling up with water. I can hear it is trying to fill but it then stop and give 1 flash every time. The dishwasher have no display panel. I turned it 45 degrees backwards. some water ran out but it is still doing the same. I check both the inlet and outlet hoses and could not see any damage. I tested the machine with the door open and with the filter in the middle. I could see that there is water coming through as the machine try every time to start in the hole where the filter goes. I also could see little bit of water going out via outlet
    Master:
  • Whirlpool Master
  • 489 Answers
Thanks for the detailed description of the symptoms that we should make it easier fault detection.
I conclude that there is a mistake F1 (1 x flash,1s pause,1 x flash).
Before anything, erase the failures by pushing the START button for longer than 1.5 second.
F1 - NTC break
Temperature out of the normal value (-3°C till +85°C)Temperature inside higher than +85°CNTC defectiveDishwasher is frozen, less than -3°C If temperature is less than -3°C, fill the appliance with a cup of warm water to warm it up before you start it. The failures F1 (NTC break) and F9 (continuous water inlet) are checked and indicated immediately after start program. Because that, too small quantity water is taked.
First, I suggest to measure the resistance of the NTC, which must be about 58,1 kOhm at temperature 20°C. Also, check wiring between NTC and board.
Dado
ADP 4305. Where can I obtain a service manual? - 25899929-dusrtgidcvi21rrowxclytp3-1-0.jpg
Posted on Oct 12, 2015
Testimonial: "Dear Dado thank you for replying... much appreciated! I emailed videos to the Fixya Team. Also a photo of the dishwasher parts to attach to my question. many thanks."
  • Gregory
    Gregory Oct 12, 2015
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes
Hello Simon,
No water in the tub would indicate the drain is clear (unless it never filled at all...have you confirmed? Do you hear water leaving the unit?).
Those bleeps and flashing lights are of course the machines desperate effort to tell you it's problems and the code may be in the owners manual or a call to the manufacturer.
I'm a big one for checking grunge accumulation and would ensure the discharge hose is clear. This gets back to hearing water leaving the machine. You may need to pull the unit to check the hose, although a common blockage is right at the connection to your disposal.
Also, check for debris under the filter screen in the bottom of the tub, another place detritus accumulates.
All the best.
Nov 22, 2014 | Dishwashers
Hotpoint whirlpool ADP 4502/5
It's trying to fill with water and there is debris in the pump assy. Please remove the debris and restart the unit.
Mar 11, 2014 | Dishwashers
Flashing but nothing happening
A-- If you hear the water filling for 3 minutes before the lights flash, 2 things could be happening:
a.1) water never reached the proper fill/run level so the computer prevents the heater from starting and alerts the user. There should be a code list in the troubleshooting section of the user manual describing the blinking lights and what they mean.
Solution- verify by sound if water flows at the same rate as the sink tap, if not then shut off the water and check the inside the connection hose for debris against the screen inside the hose end or insid ethe machine end where there is a intake valve. The debris keeps sediment out so it works but there's no auto cleaner for the screen.
a.2) Otherwise the heater itself is faulty meaning it does not conduct an electrical path or maybe overheating (could be dry) and the computer senses the wrong temperature either too high or too low.
Solution- A service call to determine the reason why; heater continuity, water valve, heater relay, hi-temp fuse, etc.
B-- Now, if you do NOT hear water filling for those first 3 minutes, 3 things could be happening;
b.1) House water supply is turned off.
b.2) hose is clogged (see solution a.1 above)
b.3) Drain pump inside dishwasher was clogged during the last run and old water didn't drain out (maybe some water is evident in the tub bottom).
Solution- Most dishwashers start each wash cycle with 30 second drain pump running to make sure the tub is completely emptied so the next fill cycle can't overfill. This ensures that if the user finds a 3 liter pot that flipped over during the last wash and if they dump that full pot of water into the unit to make it lighter, that the water will get drained before the new water enters the tub.
If the drain pump is clogged reset the power and restart the wash cycle. Note how much water is in the tub and see if it goes down any during those 30 seconds by opening the door afterwards. Find the clog either a bone or plastic bag or some small pice of a childs toy is stuck in the drain pump or the other end is clogged maybe by grease or bones if you have a sink disposal unit. The things they grind up drop into the drain 1" inch above the hole for the dishwasher drain tube.
NOTE: There is also an overfill [float] switch if the water inlet valve gets stuck open and the water keeps filling, the drain pump is switched on until someone comes and shuts off the water supply. When the tub drains the float drops and the drainpump stops. This will also make lights blink so check the user manual for codes or call the factory service reps [1-877-337-3639].
Either way, there should be instructions to reset the machine for restart. If it doesn't reset you need someone to fix the control that tripped the unit, maybe a safety fuse or a broken piece of the puzzle.
Aug 17, 2013 | Haier DW12-PFE2 24 in. Dishwasher
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool duet Washing Machines
I HAVE A DISHWASHER ADP 81 THAT GIVE "F6" ERROR. WHAT IS THE PROBLEM THANKS
An F6 is a water inlet fault, basically it's saying i have no water coming into the appliance, check to make sure the water is on and flowing to the hose, failing that it could be the reg dasoge which is the side chamber that feeds the water into the appliance there is a tiny board on this that sometimes blows or it could be the whole reg dosage(water chamber) that is faulty as it has a wheel inside it that counts the revolutions as the water comes in and once it has reached a certain count it will tell the appliance to stop filling if this has blocked up and the wheel cannot count then it won't fill either.
Nov 04, 2010 | Whirlpool Dishwashers
It keeps stopping flashing LF,I don't have the manual,what does LF mean?
Hello there:
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. furthermore please check the following that may apply
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet
Aug 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool adp 8540 - 7 flashes
replace the control board in the console
Apr 10, 2008 | Dishwashers
Dishwashers Logo
157 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
