Question about Mouse Systems Mouse (The Mouse model) by Ball style mouse ONLY 1 LEFT (400DPIMOUSE)
Usb mice work for a few weeks and then **** out. wha?????
Does anyone have this mouse problem or know how to fix: I've bought at least 6 mice and each worked well for a couple weeks and then just died.When I attempt to troubleshoot, the computer always tells me the device is working just fine. Happens no matter what type of mouse, wired OR wireless, or which computer (laptop or desktop). Am I the only person on the planet having trouble with this? Just before the mouse starts acting up, my computer gets slower and slower and starts all kinds of aggravation, window freezes, etc. Help meeeeeeeee pleeeze!!!
A computer mouse can give you many headaches
Question 1: My serial mouse just isn’t getting detected by Windows Plug and Play. What can i do?
Answer: What I'd do is to manually try to add the mouse via Add New Hardware in the Control Panel. Short of that, try to make sure your serial to USB connector is up to date. Older ones may give your serial mouse problems.
Question 2: My mouse isn’t responsive to double-clicks. Why?
Answer:
Older mice tend to have this problem. Switch out the mouse and try with a newer one to see if the problem is solved. If it works, the first mouse has a problem. If it still doesn't work, then you should go into the Windows Control Panel to slow down the double-click setting, then see what happens.
Question 3: My mouse keeps jumping across the screen in bursts. Why?
Answer: This behavior happens is your mouse is connected to a serial port using a 16550 chip. Don't worry if that sounds cryptic - what you need to do is to go into your computer BIOS and toggle the FIFO (first-in, first-out) hardware buffer. There should be an option for this. Toggle it, then see what happens.
Question 4: If I move the mouse away and then back, it continues past the sticking point. Why?
Answer:
This one is usually due to dirt in the mouse, especially if you have a mechanical one. Remove the mouse ball and clean out any dirt you find.
Question 5: So how do I go about cleaning my mouse?
Answer: Here is the procedure. Unplug your mouse from the PC, then get a soft tissue and some cleaning fluid. Remove the mouse cover, then clean out the mouse ball to remove all dust and dirt. Also clean out the rollers within the mouse. Once done, pop the cover back and your mouse should be spick and span.
Conclusion
That's a list of the most common questions and answers about the computer mouse. The next time you have computer mouse trouble, be sure to check out these answers first. Good luck! Mike H
Posted on Jul 14, 2009
  • 30 Answers
If your mouse have a ball inside you can clean the roll inside sometime dust on it and do not rotate
Posted on Jul 13, 2009
Onn Wireless Mouse has stopped working. What do I do?
Mine would work fine until I turned on my wireless headphones...then the mouse would move a little stop.....move a little....then stop.
I made sure my headphones were on.
I turned off the mouse, moved the mouse reciver to a USB port on the front of my computer (the mouse reciver and the headphone receivers were next to each other on the back of the computer). I turned the mouse back on.
The computer imediately gave me the "installing USB driver" notification.
When it was complete....both played nicely together...no more problems.
Jun 28, 2012 | Computers & Internet
Gaming mouse cannot detect
try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
Jun 13, 2012 | Computers & Internet
Onn wireless mouse stopped working
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top bottom
or you might use the safe mode option
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red X right update driver
W7
hope this helps
Feb 12, 2012 | Computers & Internet
I bought my mouse and it just stopped working.
If tat has an USB interface, try inserting it in other usb ports. May be due to conflicts of drivers
Sep 07, 2009 | Apple Mouse
Belkin wireless travel mouse F5L017-USB
if the prob is within two weeks then do the system restore,take the computer to an earlier ti when the mouse was working fine...hope it will work...
Jan 27, 2009 | Micro Innovations Wireless Optical Travel...
Interlink 4350 wireless mouse won't work
You probably already tried this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 03, 2008 | Interlink VP4350 Mouse
Mouse only works for a few seconds and then stops.
have you changed the batteries recently? Wireless mice seem to eat batteries faster. I have a Dell wireless mouse. It will work fine for months and then nothing. That's when I know to change out the batteries. If your batteries are fresh, make sure they are seated in their slots securely.
Dec 02, 2008 | Belkin F8E825 USB Mini Wireless Optical...
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
Cursor sliding off screen
I?ve had this problem in several Logitech mice. In every one of my cases the problem was resolved by uninstalling the driver and reinstalling the latest OR just using the default Windows driver. In some cases with USB mice I had to shut down the PC, remove the original mouse and replace with a standard PS2 mouse, remove and reinstall the driver and then reattach the USB mouse without rebooting. After a successful test you can shutdown the PC and remove the PS2 mouse. Let us know if that works and if you have any other questions and thanks in advance for rating this post.
Apr 01, 2007 | Logitech Cordless TrackMan Optical...
Computers & Internet Logo
227 people viewed this question
Top Mouse Systems Computers & Internet Experts
David Payne
David Payne
Are you a Mouse Systems Computer and Internet Expert? Answer questions, earn points and help others
