Question about Cell Phones
Display problem hi i have took jmax J95 mobileits display has gone. can some one help me out where i can get its display
Digital speedo and display very dim on z750
Hi
Sounds like you have a faulty connector/wiring to the display unit, most likely a bad connector (known as a dry joint) leading from the ECU junction relay box. Dry joints/circuits a sensitive to vibration!
Getting the wiring checked by an auto electrician to make sure where the fault is actually in the wiring.
If the fault is a dry joint in the wiring, re-soldering the connector will fix the fault.
If the fault is a bad wire, replacement of the wire will fix the fault.
If the fault is a dry circuit in the display unit, replacement of unit necessary(costly & worst case).
Have a full Kawasaki service manual for the bike on an USB STICK in PDF form with you, when you take the bike to the auto electrician, it will help them find the fault quicker & cheaper.
If you haven't got a full service manual, you can download PDF file from the internet, the cost very minimal compared to a printed manual.
When I had my problem with the electrics on my Z750S, the fault was with the connectors(dry joints) and re-soldering them solved the issue!
Hope this helps
Apr 08, 2014 | 2008 kawasaki Z750
My htc chacha display is not working can it be fixed?
yes, it can be repaired.
just go to good/well known mobile repairing shop in mumbai and they will help you through this.
don't goto chip repairing shop they'll definiately screw your phone.
Jan 17, 2013 | HTC Chacha Smartphone
Jenn-Air JDS9860AAW Touchpad display error F-7
Hello, Thank You for using FixYa. I will be helping you today.Its a problem with th touch membrane. These had allot of issues with this. Sometimes just unplugging and plugging the ribbon cable from the control to the touch-pad a few times fixed the issue. I would try that first.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Jenn-Air JGS8850ADS Gas Kitchen Range
My Sony DSC T200 display has gone..I see white vertical lines on it. But the picture i took is fine? What would have happen and what is the cost of repairing it?
Hi your unit has lcd defective. you can do your self or bring to your local repair shop. They would charge around $115 to 165 depend on what they really want to charge.
thanks and best regard!
May 26, 2011 | Sony Cybershot DSC-T200 Digital Camera
The treadmill will turn off while in the middle of a run. After a couple of min. it will turn back on.
hi, please check when machine turn off display is gone or not ,IF display is gone pls check power point, IF display is not gone check the current rating with load ,
Dec 09, 2010 | Spirit Esprit ET-8 Foldable Treadmill
Hi i have a Panasonic surround sound model SBWA15 which is about 5 years old. The machine switches off and displays 'F76' in the display screen. i took it to a repair shop and they say the outputter has...
I have PANASONIC MODEL NO. SB-WA15, the radio works but when i try to work it witht he t.v. it does not come through the speakers. what do i do? i need help before the superbowl tonight!
Aug 05, 2010 | Panasonic SC-HT17 System
How do I stop the jingle when i send a text message on my Samsung C3050 mobileit occurs when the message is sent
Generic comment.
There must be a feature in your phone set up that control this fedature ... find it and turn it off.
Conversely, you could turn the volume of your phone down before you starte sending text.
Sep 27, 2009 | Cell Phones
Install game in j-max mobile
how can i install games in j-max mobile model f1
Apr 12, 2009 | Siemens M56 Earbud Hands Free Headset
I have a Nikon coolpix s210 we had a couple hundred pictures on the camera, but this morning my wife took a couple pictures and all but those two are gone.
Go into the "play" menu and check for another folder - or set it to display ALL FOLDERS. Please leave feedback if this helps.
Jul 26, 2008 | Nikon Cameras
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
