Question about GE GSH25JFR Side by Side Refrigerator
Freezer is cold emnough, it's the refrigerator
Freezer is cold enough, it's the refrigerator side that is not cold enough.
tried turning the temp stting to max but does not seem to help.
    President:
  • 942 Answers
Hi..
If your refrigerator is not cold enough you need to check this
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!!
Regards
PCmania
Posted on Jul 13, 2009
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Freezer fan stays on constantly. temps ok in both sides. will this cost much more electricity and should i really worry about it.
If the freezer fan is running constantly, and things aren't too cold in either section, it means the frig thinks its not cold enough to shut off, so it runs trying to get to the proper temp. you have control set at. Check for any frost buildup on freezers back panel inside freezer. If there is you have a defrost problem.
Oct 01, 2011 | Hotpoint HSS25GFP Side by Side...
I have a model GSS20DBMD side by side model,It has frost on the back of the freezer and the temp is not cold enough to freeze water in that section, also, the refrigerator side is not cold enough . the...
You must replace the defrost heater and defrost thermostat inside the freezer. Remove the shelves and bins,then remove the rear panel of the freezer to access the parts.
Sep 08, 2009 | GE Refrigerators
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Why does freezer get cold but not refrigerator side?
Check the freezer temp (available in most grocery and home improvement stores). The temp should be between 0-10 degrees F (not just barely below freezing).
You can also try to find a solution on www.repairclinic.com or click here.
Aug 13, 2009 | KitchenAid KSRG25FKSS Side by Side...
I have a GE side by side refrigerator GSH22JST and frig is cold but freezer is not cold enough (soft ice cream)...heavy frost is building up on bottom half of evaporator. I can force defrost mode through...
Okay,
What is your Freezer temp rating?
Did you check the refrigerant PSI rating?
Is your condenser restricted?
Let try adjust refrigerator to less cold and adjust more cold for freezer. and see what your temp rating.
nguyen@ite.net
Jun 09, 2009 | Refrigerators
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
GE GSH25JFR Side by Side Refrigerator Logo
465 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
