Apple iPad 2 Logo
L
Lloyd Morgan Posted on Oct 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a I pad and it is frozen and unresponsive. I cannot reboot it and it and the screen is not responding to any attempt to do anything.
The screen is unresponsive to everything. I have tried to reboot it and I cannot reboot. it will show the slide to power off but it does not respond to the action.
De ice
Level 3:
Diehard:
Visited the website for 60 consecutive days.
  • Apple Master 711 Answers
  • Posted on Oct 08, 2015
De ice
Apple Master
Level 3:
Diehard:
Answers
711
Questions
Helped
175397
Points
3800
Just got this NuVision tablet from pawn shop model number 7 85 M3 and I did a factory reset on it and when I restarted it the screen doesn't respond to my touch how do I fix it
Sorry to read this about your tab.
You may have to Hard Reset your tab once again to see if the unresponsive screen will start responding to touch.
Attempt hard reset for a couple of times (in case once does not correct this fault; alloe small time intervals in-between while you hard reset your tab)
Hope this helps. In any case, do post a feedback.
All the best.
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
2answers
How to reboot an iPad, a video clip is stuck on running
Rebooting is easy. It is called a hard reboot. Just hold both buttons down until you see a red slider, and then slide it to shut down. It will restart, and you will see the Apple logo.
Touch screen unresponsive
Have you tried re-loading the firmware?
See this page for your tablet. Support Firmware
2helpful
2answers
Ematic tablet screen is frozen
Well I'm trying to fix a ematic tablet because it frozen
Reset tablet screen
I'm not sure if this is what you are looking for but.. If your device is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu mode, select Settings >Privacy >Factory data reset >Reset Tablet>Erase everything
32helpful
2answers
The screen has frozen in e mail and i cannot switch off or move to another function or do anything
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
