Question about Freezers
My Kenmore upright freezer suddenly stopped running. Initially the GFI on that circuit tripped. The breaker in the main panel did not. (Curiously, today's weather was about 15 deg cooler than the previous weeks temps, so it doesn't seem like the compressor would have been working as hard today.) Once I reset the GFI, the refrigerator that is plugged into the same outlet restarted, but the freezer did not. I was wondering if there is a circuit breaker somewhere on the freezer? I did not want to open the door to check. This freezer is from about 1996 or 1997. Thanks, Dave LeFevre Olympia, WA
  • davelefevre3 Jul 13, 2009
    Since it took almost half an hour to get your response, I pursued my own solution.
    I started up my emergency generator and connected it to the freezer.
    The freezer started working again.
    I was wondering about your diagnosis of a defrost/heater problem.
    I am trying to figure out how that could that cause the GFI to trip.
    That was the primary problem.
    The freezer was warm enough by the time we discovered the problem that I don't think the defrost cycle would have kicked in.
    Thanks,
    Dave LeFevre
    Ah, I see the confusion.
    I mentioned the freezer is an upright freezer. The refrig is a separate unit.
    (I also mentioned the frig and the freezer were plugged into the same outlet.)
    I also asked a question in my first email that I am still wondering about.
    Is there usually a circuit breaker somewhere in or on the freezer unit that can be reset (in case I run inot a similar problem again)?
    Thanks,
    Dave LeFevre
  • 1,000 Answers
Dave,
The freezer does not have a circuit breaker to reset. I am curious as to why there is a GFI socket for the refrigerator and freezer. Unless there is a water source near the two appliances, there really is no need for that type of outlet.
If the GFI is older or has been installed for a long period of time, they can get "weak". If this is the case I would definitely replace the outlet.
I assume both appliances are on a minimum of a 20 amp circuit, but really should be on separate circuits if there are additional loads on the same circuit.
Let me know.
Regards,
Posted on Jul 13, 2009
    President:
  • 2,777 Answers
Sounds like you probably have a defrost problem. It's either the defrost timer the defrost heater or the defrost thermostat. Remove the back wall of the freezer. Use an Ohm meter to check the heater and thermostat. You should get a reading of 0.0 on both. If you get a reading of 1, it's bad. If both check OK replace the defrost timer.
Hope this helps, if this doesn't take care of the issue then I would recommend you check with a local service person as any other problem is going to be far too difficult to diagnose remotely, especially via a "chat" type setup.
Thanks for your time, good luck!
Tim
  • Tim Grayson
    Tim Grayson Jul 13, 2009
    Glad to hear you have it working again. The defrost issue I referred to could have caused voltage issues which can cause a breaker to trip. When you described that half the unit was working and the other half was not that lead me to believe this could be the issue. I am not sure how exactly you resolved the issue (meaning how that would work but your regular outlet didn't) but I am definitely glad it's fixed!
    Thanks so much, have a nice evening.
    Tim
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
No power while plugged
It probably has a circuit breaker located on the bottom of the fridge, behind the front filter. Also try looking inside the refridgerator side at the top. It may be red colored to indicate it is safety-related. Just push it in - but don't be surprised if it trips again.
WARNING: RESET ONLY ONCE TO AVOID A FIRE OR ELECTROCUTION SITUATION.
You may have an internal problem, in which case the freezer's circuit breaker is your best friend!
Note that the self-defrosting freezers have a timer that shuts them off periodically so they can defrost. Sometimes the timer does the defrosting in the middle of the day, giving the appearance of a failure. This could be your problem.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Aug 31, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
Tripping the breaker
Check the start relay. If it is OK the compressor is bad.
May 12, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
No light on door and motor not running
Have you checked your breaker switches in the circuit box? If tripped, the breaker will rest in a half way position.
Turn it all the way off and then back on.
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
sounds like you have compressor lockup-mike
Oct 22, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
81 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
