Question about Dell Inspiron 15 3521 15.6" Laptop Computer - Black Matte with Textured Finish; Intel i5-3317U; Microsoft Windows 8 Home; 6GB DDR3-1600 RAM; 750GB 5,400RPM Hard Drive; Intel HD Graphics; 8x DVDRW Drive; 8-in-1 Memory Card Reader; 1703 802.11b/g/n Wireless
Shaky trackpad cursor on Dell laptop
If i touch the trackpad the cursor begins shaking to the point that it can barely be controlled. It's fine while typing or when using mouse
SOURCE:
SOURCE: Dell Laptop Trackball Too sensitive!
Go to control panel. Select mouse. In the window that opens, select the dell touchpad tab. Click where it tells you.
Then, on the bottom left of the next window that opens, select "pointing stick settings." Uncheck the "tap to click" and the TouchCheck "Enable" boxes.
That seemed to work for me. you can also disable the touchcheck on the touchpad.
Posted on Jan 03, 2008
coldsilver20
  • 113 Answers
SOURCE: Dell Cursor Typing Blinking Problem
this is because you must deactivate your touchpad. you can do this by holding the Fn key and pressing the F* key that shows a picture of a touchpad in the same color as the Fn.
or you can go to control panel and turn it off in the mouse settings. but just attaching a mouse will allow the touchpad to stay active and therefore still be sensitive enough for your hand to "tap" th cursor.;
Good luck and pls rank this response! :D
Posted on Mar 16, 2009
  • 11 Answers
SOURCE: Dell Inspiron 1526
your touchpad is just one case to sensitive. deactivate it by hitting "fn+ the tuchpad deaktivation key on your keyboard" and get yourself a mouse
Posted on Aug 05, 2009
SOURCE: laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Posted on Oct 23, 2009
SOURCE: Dell Inspiron 1545 laptop keyboard cursor jumps to
Go to http://support.euro.dell.com/support/index.aspx?c=uk&cs=ukdhs1&l=en&s=dhs
Click the drivers and downloads section.
Enter your service tag number and procced to the download section.
Click Input Device Driver and dowload the alps touchpad exe file. Run this and your problems will be solved.
Posted on Oct 28, 2009
Touchpad quit working for tapping
check for your trackpad settings mainly in the system tray icon on the bottom right corner and then right click the trackpad icon and make sure that tap to click is enabled.
if the icon is not there in your icon tray then look for it in the control panel and enable the tap to click option...
hope this helps
Jul 13, 2012 | Gateway Computers & Internet
Cursor gets stuck
make sure you are not touching more than one finger two you touch pad. You can disable multi touch gestures from the system preferences pane.
And also insure that your trackpad is clean as sometimes that will prevent the pad from detecting you pressure.
May 24, 2012 | Computers & Internet
Cursor on my toshiba sattelite is locked
Hi
This is not automatic lock but you have turned off the trackpad
Hold the Fn key and press F9 key this will re-activate the mouse and then you can use it.
It is provided to turn off because then you type if your palm touch the trackpad the cursor will move and you may start typing somewhere else.
DO RATE MY SOLUTION.
Jun 29, 2011 | Toshiba Sattelite A105-S2051 Notebook
I have a Toshiba LapTop Windows 7 My granddaughter pushed keys and now i can't get the cursor to move. I have tried shutting down and it is still frozen in the middle .
Are you using the trackpad to manipulate the cursor, or are you using an external mouse?
If you're using the trackpad, it may be as simple as using the Fn keys and the corresponding F keys at the top of the keyboard to enable the trackpad feature again. If that doesn't work, try plugging in an external mouse via USB port to see if that works.
If you're using an external mouse, then try to see if the cursor moves while using the trackpad.
Hopefully one of these options will give you control back over your cursor again.
May 03, 2011 | Toshiba Satellite Pro L300 Notebook
My cursor has suddenly developed a mind of its own and floats around at will! How do I solve this please?
Keep the palms of your hands away from the "touchpad" -- it's sensitive to objects that don't actually touch it, but come "close" to it.
Also, check that none of the "arrow" keys on your keyboard are "stuck" in the "down" position.
If necessary, use CONTROL PANEL to "disable" the touchpad, and connect an external USB mouse.
Nov 18, 2009 | Dell Latitude D600 Notebook
Toshiba U305-S5077 trackpad will not click by touch anymore
The touchpad driver might need to be reconfigured. Try the various options in the Control Panel and then Mouse properties.
Aug 17, 2009 | Toshiba Satellite U305-S5097 Notebook
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
Unstable cursor
Mainly this is due to your power supply adapter problem.It will be stable when the laptop running in battery i.e without adapter connection
Sep 28, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Dell Inspiron 1526
Jun 22, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 15 3521 15.6" Laptop Computer - Black Matte with Textured Finish; Intel i5-3317U; Microsoft Windows 8 Home; 6GB DDR3-1600 RAM; 750GB 5,400RPM Hard Drive; Intel HD Graphics; 8x DVDRW Drive; 8-in-1 Memory Card Reader; 1703 802.11b/g/n Wireless Logo
106 people viewed this question
Clive
Clive
Alun Cox
