Question about HP Pavilion dv6000z Notebook
One long beep followed by two short beeps.
Once I turn my computer on it has one long beep followed by two short beeps, takes me about half an hour to turn it on. Sometimes when my labtop turns on the screen resolution is all blury and large. Please help!
  • HP Master
  • 32,281 Answers
This POST error code means there is a video card problem.
On laptops the video chip is part of the motherboard and the video RAM is shared (part of) the main RAM modules.
The RAM maybe faulty or needs reseating. Reseat the RAM modules to see if the problem goes away. You can also get the RAM tested at your friendly computer shop, if the RAM is OK the you have a faulty video chip on the motherboard. The cost of replacing the motherboard may not be worth it.
Posted on Jul 13, 2009
  • 112 Answers
That is a video error code. There is a known issue with nvidia/hp video cards. Suggest reading this for more info.
Why does my computer light come on but want boot and want show a screen and making a beeping sound
In simple terms, you have a hardware failure, probably in your motherboard, hard drive or memory.
The beeps your hearing, are there for a reason. The way it works, is, when you first turn a computer on, it goes through a "Power-on, self test", (know as a POST).
During this period, the BIOS queries the system hardware, such as the hard drive controller, the i/o ports, the memory, etc. and expects to receive back a specific return code which indicates that the specific hardware is running properly.
If it finds a failure in some element of the hardware, it will issue a specific pattern of beeps to tell you which part of the system is failing. (It does this because the system may be unable to display the error on the screen).
Each of the different BIOS manufacturers (BIOS is an acronym for "basic input output system, the hardwired code that talks to the actual hardware), have their own series of short and long beeps, for the different type of failures. So to know where the failure is, you must first know what BIOS manufacture you have in your computer.
Some of the more popular manufacturers are: AMI, Award, IBM, Phoenix, Macintosh, etc.
When you first turn on our computer, the display will report which brand of BIOS you have, and its version.
Once you determine the brand, you can go to any number of web pages that have a cross-reference for the beeps for each brand on BIOS.
I think most adhere to the old IBM PC beep codes as follows:
No beeps: no power, bad CPU,
1 beep: normal
2 beeps: POST/CMOS error
1 long beep, 1-short beep: motherboard problem
1 long beep, 2-short beeps: video problem
1 long beep, 3-short beeps: video problem
3 long beeps: keyboard error
Several long beeps: memory failure (most common fault)
Continuous hi-lo beeps: CPU overheating
You can check with the following websites to get an idea of what's going wrong.
Computer POST and beep codes
How to Diagnose Computer Beeps eHow
Often times a SIMM has come loose in its slot (or corrosion on the connector tabs). If your getting a memory error, you can try opening the box and try re-seating each of the memory Simms to see it that might be the problem. (When you have them out, look at the row of pins along the bottom and see if any look corroded.)
Aug 25, 2014 | E-Machines eMachines Desktop PC
Medion NoteBook :LT 9886 The "Battery
The battery is shot and needs replacing.
Jun 30, 2008 | Medion Computers & Internet
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Gateway wont startup. One beep followed by two short
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
Nov 12, 2013 | Gateway GT5678 Desktop PC
When rebooted computer beeps 3 times and will not turn on
Is it a long beep or a short beep? Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: AverageTime Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code
Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard'sBIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How To Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Tips:
  1. Still can't figure out what the beep codes mean? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum.
Jan 03, 2013 | Dell Precision T5500 Computer Workstation ...
Acer aspire long ans short beep error
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive IDE SATA
Make sure they have a secure dust free connections if its a flat 40 pin ide it will be the first to fail
Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it.
Restart your computer the found new hardware wizard should activate
A computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function.
Make sure all leads that are attached to your drives dvd\cd and floppy drive have secure Make sure the connections and are not faulty or just replace them they could be faulty
A computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error.
Also check the Keyboard for secure dust free connection ps2 and or usb.
Click start control panel administrative tools computer management device manager scroll through devices if you see a yellow Question / Exclamation ? ! or a Red X a new driver will need to be installed / updated.
Right click to update driver.
If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
This is a free driver solutions.
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Dec 01, 2012 | Acer Aspire M1202U1850A PC Desktop
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
My computer always beep. when i am printing my computer beeps very long so i turn it off. i thought it was the cpu overheating. i put some thermal paste and turn it on when the computer is in the desktop...
hi Robin.
if your computer is making a beeping sound when it starts. No, you're not crazy, your computer really is beeping, and the sound may be coming from inside your computer, not your speakers.
These beeps are called beep codes and are used by the BIOS (the software that runs your computer hardware) during the POST (an initial test to make sure your computer is OK to start) to report certain initial system errors. If you're hearing beep codes after you turn your computer on, it typically means that the motherboard has encountered some kind of problem before it was able to send any kind of error information to the monitor. The beeping, then, is a way to communicate a problem to you when the computer can't show a proper error on the screen.
Follow the steps below to determine what computer problem the beep code is representing. Once you know what's wrong, you can work to fix the issue.
How to Troubleshoot Beep Codes
Figuring out why your computer is making beeping sounds should only take 10 to 15 minutes. Solving that problem that you identify is another task entirely and could take a few minutes to hours, depending on what the problem ends up being.
  1. Power on the computer, or restart it if it's already on.
    Restart your computer if you need to hear the beeping again. You're probably not going to make whatever problem you have worse by restarting a few times.
  1. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short (or all the same length), and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    I know this might all seem a little crazy but this is important information that will help determine what issue the beep codes are representing. If you get this wrong, you'll be trying to solve a problem your computer doesn't have and ignoring the real one.
  1. Next you'll need to figure out what company manufactured the BIOS chip that's on your computer motherboard. Unfortunately, the computer industry never agreed on a uniform way to communicate with beeps, so it's important to get this right.
    The easiest way to figure this is out is by installing one of these free system information tools, which should tell you if your BIOS is made by AMI, Award, Phoenix, or another company. If that doesn't work, you could open your computer and take a peek at the actual BIOS chip on your computer motherboard, which should have the company name printed on or next to it.
    Important: Your computer maker is not the same as the BIOS maker and your motherboard maker is not necessarily the same as the BIOS maker, so don't assume you already know the right answer to this question.
  2. Now that you know the BIOS manufacturer, choose the troubleshooting guide below based on that information:
    Using the beep code information specific to those BIOS makers in those articles, you'll be able to figure out exactly what's wrong that's causing the beeping, be it a RAM issue, a video card problem, or some other hardware problem.
  3. Try to turn off beep sound in the BIOS
More Help with Beep Codes
Some computers, even though they may have BIOS firmware made by a particular company, like AMI or Award, further customize their beep-to-problem language, making this process a little frustrating. If you think this might be the case, or just worried it could be, almost every computer maker publishes their beep code list in their user guides, which you can probably find online.
See How to Find Tech Support Information
Dec 13, 2017 | Biostar MCP6P-M2 Motherboard - v6.0,...
Laptop does a long beep, followed by two short beeps.
One long followed by two short beep IS a video error. However, your model laptop does not have a separate video card. The only fix is to replace the mother board. Here is the service manual that will show you how to take apart the laptop and even give you the part number you would need to replace the motherboard.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | Computers & Internet
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Aug 12, 2008 | Timex 27191 Wristwatch
HP Pavilion dv6000z Notebook Logo
532 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
