Question about Bosch Dishwashers
How do I descale? We have extremely hard water. The interior of the dishwasher has a residue build-up in places.What would you suggest? I regularly clean the filters and traps.
  • 417 Answers
you can try TANG orange juice crystals. Its sounds strange but try it. Try two cups,( just put it in the bottom) and run it through a regular wash cycle. If that doesent work they sell the expensive stuff at the appliance store.
J
Posted on Jul 13, 2009
  • Jude Meredith
    Jude Meredith Jan 24, 2010
    Hi Again,
    theres one thing I forgot about this post. put the crystals in and then put the dishwasher on rinse and hold setting, or if you dont have that setting close the detergent door and then run your dishwasher untill you here the detergent door POP open, then open the door and put the crystals in then. if you just start the regular cycle, it wont clean the interior as well.
    sorry!
    jm
I am worried about the build up of residue of something in the water that causing problems with the coil
the build up will be calcium from that is formed by the boiling water and a high mineral/lime content in the water supply
there are descaling products on the market that you can use on a regular basis to clean the lines
talk with a boiler retailer / manufacturer as to the process and descaling products
Nov 13, 2016 | Washing Machines
I keep having problems with the salt. I have put it on a clean cycle twice. I have washed out the spray arms but everything is covered in salt which is hard to remove.
That isn't salt. That is residue from extremely hard water. A water softener will stop that build up and will help to remove that same buildup from the water pipes throughout the house and will extend the service life of your water heater.
Jul 09, 2016 | Dishwashers
There seems to be a "white residue" on the interior of my dishwasher. I tried running a regular cycle using 2 tablespoons of lemon juice as recommended by Asko, but the problem still remains. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 03, 2011 | Asko D1796FI Built-in Dishwasher
Stainless steel drum-some hard water build-up inside leaving residue on some dishes...how do I clean interior of dishwasher. A home-made solution worked years ago but have forgotten the ingredients!
heatman101
[][][p
Sep 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Residue on dishes/glasses - Hard water? How to clean?
heatman101
Mar 01, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
How do I properly clean the coffee maker and then get the light to go off?
  1. Allow the unit to cool completely and unplug it before cleaning. use a sponge dampened with soapy water to clean the outside of the coffeemaker, then dry carefully.
  2. Open the reservoir cover and the filter compartment. Remove the coffee grinder lid, the grinder, the filter basket, its cover and the support.
  3. Wash the pieces along with the measure, the carafe and its lid in warm, soapy water, rinse thoroghly and dry. Then replace them in the unit.
  4. All these pieces are also dishwasher safe.
  5. Never pour water inte the unit when the grinder is not in place.
  6. Wipe the part under the filter basket and the heater plate with a damp cloth.
  7. Do not wipe the inside of the reservoir as this may leave fabric or paper residue.
  8. Do not use abrasive sponges or cleaning agents as these could damage the finish.
  9. NEVER IMMERSE THE BASE OF THE UNIT IN WATER OR ANY OTHER LIQUID.
The reservoir cover may also be removed to facilitate cleaning.
Descaling.
Over time and through normal use, lime deposits will build up.
Scale can interfere with the fine mechanics and give the coffee a harsh, bitter taste. For reason, your coffeemaker should be descaled regularly to guarantee good coffee. The frequency of descaling depends on how hard the water is and how frequently you use the coffeemaker.
  • To descale, dilute 30cl white vinegar in 30cl water, pour the mixture into the reservoir and begin a brew cycle.
  • Then run two full cycles by filling the reservoir with water (but no coffee) to rinse the system.
Hope this will help you.
/Mirran
Aug 27, 2008 | Cuisinart Coffeemakers
Gritty white film all over dishwasher and dishes
Another way to descale your dishwasher is to use vinegar. This is also very inexpensive. Put a cup of vinegar into the dishwasher and run it, allowing it to go through all cycles. I would turn the heated dry off.
Please rate this solution
Aug 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
What is the best method to clean the Cuisinart Grind and Brew coffee maker? And how often?
Get descaling solution at any drug store and follow the manual on the bottle. When you do this once a month that should keep your machine in top form
Aug 17, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Dishwasher problems
Hi Bmissy,
I had the same problem with my dishwasher. In my washer the problem was caused by a buildup of water deposits throughout the machine. I increased the temperature of the water, used three bottles of "Dishwasher Magic" and now my machine is working well. I read that the rinse aid dispensers do not disperse enough of the product for extremely hard water, the solid rinse aid dispensers work better. I know that adding a little water softener to your washer when you run it can help. If you can't find "Dishwasher Magic", you might want to try running your dishwasher with a few quarts of white vinegar to remove the deposits on the coil. You may need to clean out the deposits in your washer regularly to keep the machine working well.
HTH!
Ann
Nov 02, 2007 | Dishwashers
Dishwasher not cleaning
The dishwasher salt response is acceptable for Europeans, but U.S. dishwashers do not have a salt dispenser, nor is dishwasher salt sold in U.S. stores. U.S. consumers should descale their dishwasher using Dishwasher Magic, Lemi-Clean, Lime-A-Way, CLR, or vinegar until scale is removed from the machine, then add a rinse aid to the dispenser, which should prevent future problems. For very hard water, regular, periodic descaling treatments should be done. For the vinegar cleaning, place a full cup (8 oz) of vinegar in the top rack of the dishwasher. This way the vinegar is release throughout the wash cycles, performing a more thorough cleaning.
Sep 13, 2007 | Dishwashers
Dishwashers Logo
204 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
