SOURCE: 2005 ford explorer front end noise.
Try lubing any bushings with a silcone spay lube i have ran into this before and the bushing on the sway bar links get dry and make a squeeking noise.
SOURCE: my ford 2005 explorer sport trac the windows don't work.
You may want to check the relay that goes to the primary window. This will provide support to all the other windows. However, it may not just be the window relay, it could possibly be that between your window relay and your main switch there is a short or cut wire that is causing this problem. Unfortunately, you may need to visit your Ford Dealership to run a diagnostic on your wire or if you know an electronic shop that can run one to see if it is receiving and sending power. Have them check the main door fuse and window assembly to see that you are getting power.
SOURCE: How to remove disc brake rotor on a 1992 Ford Explorer 4-wheel drive
It should just pull off once you have taken the caliper off. It may be seized in place, if thats the case try spraying the back of it with some sort of penetrating oil, let it sit for a bit. THen put some heat on it if you have torches, or beat it with a hammer. Sounds kind of crude...but it works
SOURCE: 2001 Ford Explorer 4.0 SOHC no timing marks on cam or chain
get a haynes manual and look up camshaft replacement..its worth the 30 bucks
SOURCE: Need timing marks for 2002 ford explorer 4.0
The Info I Have Is Extensive and Has Illistrations, I Need to Emali it to You As it is Very Large, This Is A Small Example Im @[email protected]
Special Tool(s)
