Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fridge began beeping and is not cooling very well despite putting temp on coldest setting. freezer is fine. friend suggested it might have iced up or blocked passage from freezer preventing cool getting to fridge. can i fix this myself?
It will likely be the fan that is in the back of your fridge that pushes the cold air up into the fridge from the freezer. Probably because the wires will have broken. You need to pull the back of your fridge out and it will be right at the bottom of your fridge at the back. It is a pretty easy fix. You will need to either replace the fan or fix the wire.
Posted on Aug 22, 2009
Fridge warm, freezer cold. repair guy said its fine if milk is not spoiling. but set at 6 coldest temp is around 40
Can you feel air movement from the freezer to the refrigerator side through the cooling tubes when the evaporator fan is operating?
If not you might have some ice build up in the cooling tube that is not allowing the refregerator to get cold enough. Try a hair dryer to clean it.
Aug 19, 2011 | Frigidaire FRS26R4A Side by Side...
Hello! I have an old model Kenmore 21 CF. The fresh food part of the refrigerator (the freezer seems fine) is not cold enough. Last night at 11:30pm I turned it from setting 5 to 7 (9 being the coldest)....
Check to see if the fan in the freezer is running, without it you get no cooling in refrigerator. If that's ok check for ice buildup on back freezer wall if so you have a defrost problem
Jun 22, 2011 | Kenmore Top Freezer Refrigerator
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Freezer is fine but the lower compartment is just cool not cold temp setting is turned to coldest
Firstly turn you temperature setting to the MIDDLE in between cold and coldest. This will allow cold air coming from your freezer to go into your fridge. if this does not seem to change your problem, check to see if the air vent at the back, top of the fridge is allowing air to flow from the freezer to the fridge. if there is no air flowing there may be a clogged ice drain or pan. usually if this is clogged you can unplug your fridge for 24 hours with the doors open. and it will manually melt the ice buid up.hope this helps
Thanks
Oct 12, 2009 | Magic Chef Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer is not cold enough - ice-cream is soggy! despite putting it on coldest; and the red warning light is permanently on. And I can't find the booklet. Help!
If the coils are frozen up already,putting the setting to coldest is the worst thing to do.Even though inconvenient,try unplugging for substantial amount of time (3 or 4 hours) to allow the coils to defrost.Be prepared for water leakage during this time.If this seems to work , chances are the defrost timer or defrost heating element are bad and the problem will recur after a week or two.
Jan 17, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
546 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
