Question about Homelite Mighty Lite Lawn Trimmer
After 6 0r 8 times of use the cord would not retract
Does it anyone know if this thing have a reset?
If I have any trable retuning this thing back I will never buy anything from this company ............. I paid moore for " a good brand" and this what I get?
2 Suggested Answers
  • 150 Answers
SOURCE: Featherlite/Mightylite 26ss pull cord will not
They don't spin with the engine, however pinning them together isn't your fix. The spring has to be fixed at both ends, sounds like one end or the other is comming out of its keeper. Check if the ends are broken
Posted on Oct 01, 2010
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Problem with retractable cord on hand mixer
Hi Sandy
Retractable cord mechanisms, after a while, can get a bit dodgy, especially with things like mixers where there may have been years of accumulated batter, frosting, bread dough, or what have you that got splattered on the cord and subsequently sucked back up into the retractor reel. They typically have an inertial ratchet that lets you pull out, but sticks on retract, unless you pull the cord all the way out to reset.
Before starting, cardinal rule is:
Always unplug before working on electrical stuff. If it's already acting up, you don't need to discover a short or a bit of bare insulation by shocking yourself or starting a fire.
With it unplugged:
  1. Pull the cord out as far as it would normally go. Depending on the exterior, give it a wipedown with a cleaning towel and a surface cleaner like simple green or windex. See if it's looking like it's coughing crumbs out of the cord hole as you pull.
  2. Let it retract all the way, then pull all the way back out. After you have a bit of cord out, pull it a short ways at higher speed, then let it retract back in, solid quick pull, slow retract. You're trying to get the ratchet to re-engage if it's gotten stuck or gummed up.
  3. If you can't get any response the above, you may have to consider whether you want to take it apart. Use a search engine to look for 'My mixer make/model service manual', or 'How to replace cord for my make/model mixer'. Likely as not, someone can go through replacement, which will give you the steps to open it up and just see if it needs cleaning. And, if something has just broken, you'll be in a position to replace it.
  4. A final thought - if it's working fine, and it's just an issue of the retracting cord pulling at the mixer as you work, you can also use a temporary cord-hold. You don't want to do anything that could pinch or cut the cord, but something like a medium sized binder clip, perhaps with a fold of tower inside , can be clipped onto the cord right where it emerges from the mixer, after you have enough cord out. The binder clips are cheap, pretty strong. and not likely to pop off without a deliberate re-opening when you're done.
Good Luck!
Nov 20, 2015 | Food Mixers
Ha-nc100
Straight up- I do not understand myself nor know how to fix your headphones retractable cord. I however instead of skipping your question chose to give you some informational insight or clues on how to gather your answer.
I have seen that no one has posted to help you as of yet so I figured giving some information on how to find your answer is best rather than to ignore your question. Here are some things that you could type into search engines which will directly take you to either or both reading and video tutorials, which will tell you how to take the headphones apart to fix their cord and or will actually show you the steps to take to fix them.
I am assuming that your question wasn't answered either because no one knew how to fix them or that because they don't know how to fix them they assumed not to make any suggestions since maybe they would had felt bad if they were to tell you to do something in which could ruin the headphones. Here is the following suggestions to go by to fix your head phones: I hope this helps:)
A. Search Engine; GOOGLE.. Search " JVC Ha-nc100 headphones needs fixing to retractable cord".
B. BING SEARCH ENGINE: " WATCH MOVIE ON HOW TO REPAIR JVC HA-NC100 HEADPHONES RETRACTABLE CORD."
C. YOUTUBE; CLICK ON VIDEO AFTER LOGGING IN, TYPE IN SEARCH BOX;
" FIX JVC HA-NC100 HEADPHONES RETRACTABLE CORD"
OR TYPE ;
HOW TO FIX JVC HA-NC100 HEADPHONE RETRACTABLE CORD"
D. YAHOO ; IN SEARCH BOX TYPE:
" MY JVC HA-NC100 HEADPHONES RETRACTABLE CORD NEEDS REPAIR"
OR
FOR YAHOO ANSWERS FROM PEOPLE ON YAHOO YOU MAY TYPE;
" HOW DO I FIX JVC HA-NC100 HEADPHONES RETRACTABLE CORD?"
YOU MAY ALSO TRY ;
" WATCH MOVIE ON HOW TO FIX JVC HEADPHONES".
I HAVE SEPERATED BY COLUMNS AND OR USING 'ENTER' FOR WHAT YOU TYPE IN EACH SEARCH ENGINE BOX IN ORDER TO GET LEAD INTO THE RIGHT DIRECTION ON HOW TO FIX YOUR HEADPHONES.
HOWEVER IF NONE OF THIS WORKS FOR YOU OR IF YOU PREFER FOR MY ASSISTANCE TO GET YOU THE LINKS MYSELF SO THAT ALL YOU WOULD HAVE TO DO IS TO CLICK ON THE BLUE LINKS WHICH WILL DIRECTLY TAKE YOU TO THE SITES THEN PLEASE LET ME KNOW AND I WILL FURTHER HELP YOU.
I THINK THAT THERE IS AN WAY TO COMMUNICATE WITH ME AND OR TO REPLY BACK TO ME. I HOPE THESE SUGGESTIONS HELP. JUST DIDN'T WANT TO LEAVE YOU ALL ON YOUR OWN TRYING TO FIX YOUR ISSUE WITH YOUR HEADPHONES:) HAVE A GOOD DAY/NIGHT.
PEACE SINCERELY,
SIGNATURE 7.:) AKA I AM UNDER THE NAME OF MARIE HAYES.
Dec 25, 2013 | JVC Audio Players & Recorders
I cant retune my proline tv/dvd combo as there is no retuning option in the limited menu.no option to reset on the controller either so have no signal now since swithover.how can i get it to reset anyone?
Some TVs brands - I believe Proline is one of them - cannot be retuned when you are in Digital mode. If you switch back to analogue mode, then press the menu button, the option to auto-scan should be available. Once you retune, switch back to digital mode.
Try this and post back if you need further assistance.
Please rate this solution if you find it helpful. Thanks.
Oct 20, 2010 | Televison & Video
Starting Pull Cord
You didn't list the model but those little rewinds are typically built very similarly.
It may sound a little crazy but it works, take the unit to a power washer such as a car wash and blow out the gook in the rewind with lots of hot soapy water and then rinse. Then using a probe or small screwdriver get the rewind unstuck. If it retracts you’re good to go if not let me know as you may have a broken piece in there and I'll need the model to know what to do next.
Jun 04, 2010 | Ryobi 15" Electric Factory Reconditioned...
CANNOT GET itv1. NEED TO RETUNE BUT DOESN'T PICK
Good Day,
Try this to reset your programming, but try to reset the whole set by unplugging TV and BOX from power source for 3-5 minutes then plug power cord back into power source. If that does not work try this:
Option Menu Setup
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "0", "1", "7", "0" in sequence to select
the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
Good Luck, Big IRISH>
Dec 15, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Visys time/date display settings will not stay correct - help please!
I have the same problem. I cannot believe I wasted $70 this stupid phone. No more RCA ever.
Jul 07, 2008 | RCA 25404RE3 Corded Phone
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Homelite Mighty Lite Lawn Trimmer  Logo
74 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
