SOURCE: iphone wont ring
Did you check to make sure that the "mute" switch on the left side of the iPhone is turned off (if you see an orange dot, it means mute is turned on). It may not be vibrating either because in main Settings - Sound - you haven't turned on "Vibrate" when on Mute.
I thought my iPhone was broken until someone pointed out this to me.
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
SOURCE: Intermittently my iPhone does not ring and incoming calls get forwarded.
incoming call not come in myiphone want solution
SOURCE: my iphone won't ring with incoming calls. I have
The only thing i would check is the switch on the side. Make sure its not sticking, or accidentally switched it... If its messed up, im sure Apple would replace yours! :)
SOURCE: My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
