Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Unable to download scanned documents from KM350
I'm using my office Konica Minolta 350 to scan a document using FTP.
IP for the printer is 192.168.0.250, any pc that using ip 192.168.0.xxx can scan and receive doc without any problem from the printer.
The problem is,any pc that using ip 192.168.1.xxx can connect with printer and the printer recognize the pc but the scanned document failed to be downloaded to that particular pc.
I have tested using several different pc, but the problem remains the same.
Plz help..
TQ
  • Konica Minolta Expert
  • 158 Answers
This model does not support sub addressing for scanning so all the computers would have to be in the same subnet to scan.
Posted on Oct 03, 2009
Unable to scan mail
using static or DHPC ip addressing is the proper port set up SMTP and or POP3. Mail server correctly set up.
May 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to get rid of vertical lines in scanned documents in bizhub 200?
Open the top cover of the machine and clean the small glass on the left hand side. Good luck.
Dec 27, 2012 | Konica Minolta bizhub 200 Printer
Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Feb 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning to a Computer
I googled the code and got a few returns. In a nutshell, either the LAN Cable is not connected or the destination address is wrong.
Jul 31, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning documents
You need to use the Scan to SMB function.
First create a folder, share it over your network.
Go to the MFP and under the scan to SMB enter the IP and path to the folder, enter the ID and password for the computer.
This will scan to the shared folder.
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning documents
You have to install driver with software, you can get it from www.konicaminolta.eu
Also you can scan with MS office or other Windows software, if you installed Twain scanner driver.
Find driver and software link below:
http://download2.konicaminoltaeurope.com/openmind/technic/kmbsdwl.nsf/psearch?openform&ch=MFP&dist=BEU&ui=en&dg=sw&prod=Di1610&dsg=&os=&lang=&ml=0&rid=&sub=&pcat=&pcc=
Nov 14, 2007 | Konica Minolta Di1610 Copier
Can not make bizhub c252 scanning trough e-mail feature
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
282 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
