I have a Yamaha RX-V765 which is about 2 weeks old. I have my outside speakers hooked up to the Zone 2. All worked fine for a few days. Now when I switch to a Zone 2 signal the whole receiver shuts, tried DVD player, CD, and tuner all from differnt imput. Also now all that will play in Zone 2 is my HDMI TV signal which is digital and shouldn't work at all. Thanks George
I just dont know how to put on zone 2.... its like i put it in zone 2 and nothin happens... can someone help me this is starting to **** me off..
Posted on May 18, 2010
I have 2 qustions?
my guess is that the yamaha has pre-amp outs, most yamaha stuff does, and that is the one you should be using for the main, and hooking up to the onkyo, and letting the yamaha be your zone controler, and the onkyo be your remote amp for your second zone (if your onkyo had pre-amp outs it would work how your trying to do it, but it dont) so exchange there places, and run a pre amp out to any input of your onkyo, and you'll have total volume control of your outside speakers
Jul 28, 2013 | Onkyo Audio Players & Recorders
I cant get zone 2 to work on my yamaha rx v673. They are 2 outdoor speakers.. please help
I had a similar problem where I could not increase zone 2 volume - Page 100 in the manual notes that 'power amp assign' must be set to "7 Ch + 1 zone" before zone 2 max volume can be changed. Try that.
Jul 08, 2012 | Yamaha RX-V663 Receiver
I have a yamaha RX-4659 receiver and my Zone 2 (outside speakers) had been working great for the last 3 summers. Now, I am unable to get any music to my outside speakers. When I try to adjust volume for...
Zone 2 has been switched to "EXT" in the setup menu. Switch it to "Amp" or "Int" and it should be fine. It thinks you are using an external amplifier. If you need further help, post a reply and I will help you further. Hope this does the trick for you!
May 30, 2011 | Audio Players & Recorders
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
Right speaker dead on zone 2 on my RX-V 1600 receiver
must be the right speaker wire, sounds to easy I know but maybe your wiring is grounding out the audio to that channel.
Jul 15, 2009 | Yamaha RX-V661 Receiver
Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Mar 15, 2009 | Yamaha RX-V3800 Receiver
Yamaha RX-V663 Multi-zone question.
i just got the same receiver like few days ago im still leaning it too,it is a very nice receiver though. here is some settings to help you.
check this to make sure zone 2 is showing in the menu,
on remote
menu,basic setup, speaker set,extra should show zone 2 it might show zone b...presence...or none needs set on zone 2 hit the left a-e/cat button it is weird the right doesnt circle all around? i had to call crutchfield tech for that one(GREAT COMPANY!)so that is for the setting to make sure zone 2 is set up now some to adjust the volume.
menu, manual,options,zone 2 set. here you can set 2 features
max volume( the loudest it will play) inti vol(the volume that it will play at when it is turned on) the yamaha has alot of quirks to it but has a very nice sound. for second zone features and a easier receiver to set up i have onkyo and they are very easy to set up zone 2 olume and everything on the front panel. hope you dont have to try to program a universal remote to work it seems yamaha uses discrete codes that are impossible to find i tried one universal and can only get very basic features to work.
hope this helps you out,
jeff
Jul 29, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V800 Zone 2 Operation
yes it works great. hook them up to zone B. then below the power button is a A/B button. select button B and then zone B will work.
heres the manual if it helps
Apr 02, 2008 | Yamaha RX-V800 Receiver
513 people viewed this question
 Grubhead
Grubhead
