Question about Motorola Mobility SLVR L7 Cellular Phone
How to increase the video recording length & quality
Whenevr i start recording ,it stops after 30 seconds,also recorded image have poor quality and low screen resolution
please suggest how to sole this.
    Brigadier General:
  • 7,752 Answers
It is the camera for the poor resolution, then you need to take the phone to a mobile service center for then to use special equipment to increase the recording time on the phone.
Posted on Feb 16, 2008
Hi How do I increase the length of time taking a video.
The time limit is set because the image sensor in the camera heats up. You need to give it some time to cool between shots. The record time is set so permanent damage will not happen to the image sensor. Sorry. That time cannot be changed.
Sep 30, 2015 | Canon PowerShot Cameras
I can't record longer on my easy share cx7300 camera
you can't.... it records only "video clips" without sound, maximum length of recording is 30 seconds...... and the quality is very poor, you'd be better off using an older camera-phone.
Mar 30, 2014 | Kodak EasyShare CX7300 Digital Camera
126 tape only recording 30 min is there a speed setting for recording
Hello - YES the length of time depends more on quality of recording.
The lower the quality the longer the time - or - Better the quality then shorter the time.
Try going into Video settings and try either extreme.
My camera does 10m Pixel video in BEST and 3m Pixels in Normal - so there's a factor of 3 for time.
Mar 08, 2011 | Cameras
I can't record more then 20 sec video file
I'm sorry to inform you but after researching your camera only records for 20 seconds. It has nothing to do with your card. Only 20 second blocks of time.
Movie mode - The total amount of recording time available is shown by the green "00:20" in the lower right hand corner. This is SHQ 640x480 resolution at 30fps, the maximum recording time is 20 seconds. In the lower quality 640x480 @ 15fps or 320x240 size, the recording time is limited only by space on your xD card. The shaking hand icon indicates that we have the image stabilizer turned on.
Oct 04, 2009 | Olympus SP-560 UZ Digital Camera
How to set the recording length maximum in n72
While on video mode press options and select settings. Scroll down to Video quality and change to High or Normal. On Memory in use, select memory card. The length of video recording is restricted by the available space on your memory card and up to one hour per clip.
Aug 31, 2009 | Nokia N72 Cellular Phone
My video does not record for long enough
you have to drop the resolution from the highest to atelast the middle or lowest resolution and then the option will apear when you access the video length menu to record for as long as your memory can hold. the only thing is that your device will not be able to send the video via cellular video mail when its length is too long. you also may be required to have a micro sd card installed in your device before thhe option will appear.
so recap, quality can stay fine, resolution needs to be reduced
pls rank this post,
Feb 21, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
DVD stops recording after about 30 seconds
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Sep 13, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Canon Powershot A630 video recording issue
This could be your memory card going bad. Recommend trying a "low level" format of the card to see if that jump starts it. First download all images and videos as the format will erase them from the card. Next press the menu button and select the settings (tools) menu. Go down to the format option, and press the "Func Set" button. Make sure "Low Level" format option is checked before selecting OK. After you format the card, try the video to see if the problem is fixed. If the above didn't help, recommend trying a different card.
May 27, 2008 | Canon PowerShot A630 Digital Camera
Camera stops recording video
When recording movies in the SHQ image quality mode, I am restricted to 15 seconds of recording time per movie. Why?
In SHQ mode, the FE-230 records movies with VGA resolution (640 x 480 pixels) and a frame rate of 30 frames per second. Recording this much data, this quickly, requires a large amount of camera memory and a very quick write time.
Olympus’ Type M+ and Type H xD-Picture Card media are high-speed cards and are able to process this volume of information with no loss in quality. Other commercially available media, including Type M and Standard type xD-Picture Card media, are not able to do so. For this reason, this model limits movie recording in SHQ mode to 15 seconds when using media other than Type M+ or Type H cards. The 15-second restriction guarantees that the camera will be able to process the data properly and produce a smooth, error-free movie during playback.
Keep in mind that there is no restriction on movie recording length, other than the capacity of the storage media, when recording in the HQ (320 x 240 pixels) mode.
I'm not sure if you are recording in SHQ or not. Try switching to HQ (press menu, then select image quality). It solved the problem for me. Btw I got the solution of the Olympus FAQ page on their website.
Nov 25, 2007 | Olympus FE-230 Digital Camera
Motorola Mobility SLVR L7 Cellular Phone Logo
100 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
