Question about Toshiba Satellite A105-S2081 Notebook
Under the ram panel there are 2 wires. One white and one black with the options being main and auxiliary. Which one goes on which
  • 3 Answers
Your Mini-PCI WiFi card uses black on main, white on aux!
Posted on Jul 14, 2009
Window unit wiring
If these are part of your replacement piece chances are it's an upgraded board with optional accessories. If you only had 2 before go with 2 now. Wire nut extra wires and zip tie tight. Should be ok.
Jun 10, 2016 | Frigidaire Heating & Cooling
There are 3 wires coming out the back. red, white, and black. what goes where?
The white might be a PA output. The red and black are power and ground. Which model is it?
Some models had auxiliary power outputs to turn something else on when the unit gets turned on while others had the output to the PA as one wire and then used ground to complete the circuit.
Jun 28, 2015 | Radio Communications
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Wantneed diagram for G.E. TL412CP sub panel
Do you have any wiring in the panel already? The green or bare copper wires will go the ground bar which will be screwed directly on to the inside of the box. The ground bar will be in contact with the box. If the mains are wired into the main lugs the main ground will have a green stripe or it may be bare multi strand aluminum. All ground wires go under screws individually on the ground bar. The white wires go onto the neutral bar. The neutral bar will be affixed to the inside of the box on plastic isolators that do not allow contact with the metal panel. The main neutral will have a white stripe or it may be solid white. The neutrals will go under individual screws. The hot wires will now go under the screws of the breakers. All screws must be tightned firmly but not as tight as you possibly can. The hots will be black or red. The wires should alternate black, red, black, red. Begin with black on the top two breakers the one left and the one on the right. The hot wires will be either black or red.
Feb 27, 2012 | General Electric GE 125 Amp Indoor Main...
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
How do I determine what wire (blk or white) is connected correctly to Toshiba wireless LAN card PA3613U-1MPC.?
Hi ,
The LAN card has total 4 pairs of Wire. Out of which the following are important for Data transmission.
1,3,6.
Regards.
Feb 08, 2010 | Computers & Internet
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
10-3 w/ ground wiring diagram
your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Oct 04, 2009 | Dryers
How do i wire a newworld es50s in. I`ve been having problems i`ve conected all wires and only had 2 of the hobs working
if its 240volt and you have a 3 wire receptacle, (crows foot) and the new stove has 4 wires:i.e. a RED-BLACK-WHITE-GREEN on the oven unit, your red/black are your 2 hot wires white goes to neutral, and Green is safety ground put the WHITE and GREEN together, as long as the receptacle comes DIRECTLY from the Main Panel in the House, they use a 4 wire systen in some locations depending on local codes/any new installs require a 4 wire plug install now per the N.E.C.
Aug 23, 2009 | Ovens
Toshiba Satellite A105-S2081 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
