Question about Toshiba TP50H95 50" Rear Projection Television
How do i adjust the convergence board - Toshiba TP50H95 50" Rear Projection Television
  • Toshiba Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergenhow do i adjust the convergence board - 69189a5.pngd to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 11, 2010
Blue gun adjustment does not move blue line in menu convergence function. Any way to adjust or fix?
No.Fix.Tv have dead parts on the tv convergence board.Tv colors lines R,G,B mis alignment,can't move any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead on the tv convergence board.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Toshiba 61H70 61" Rear Projection...
Red and blue pic adjustments areso out of adjustment how can i get them back
Convergence board is dead.Go to Tv repair World.com buy a new convergence board replaced the board will solved ur problems.Samsung/Akai use same convergence board.
Jan 22, 2010 | Akai PTH5498 54" Rear Projection...
Cannot adjust horizontal blue convergence on WS 55857
You still have bad grounds on the ICs. Or maybe the solder has fused another pin. If not bad grounds on the ICs you have missed them elsewhere...Really concentrate and look for these bad grounds and check your caps with a cap check. And power resistors too!!!!!
Sep 16, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Samsung pcj522r
If they tested the convergence board and thats ok, the only other Items it could be are the Digital convergence unit or the Velocity comando units that control the convergence yokes. If the convergence isnt adjustable with magic focus adjustments wont help it. Is the repair shop an authorized samsung repair facility? If you need more assistance let me know.
Jul 26, 2008 | Televison & Video
Problem with Samsung TV
SAMSUNG Convergence Problem
It looks like blue convergence. Look at menu, select convergence and see if blue top is bent down on convergence adjust screen. Probably won’t adjust.
Some Samsungs have convergence IC’s on a separate convergence board in the back of the TV. Others have the IC’s mounted on the main deflection board. Either way the board has to be removed to get at the dud IC’s and associated burnt resistors.
You remove the appropriate board, determine if any resistors are burnt or damaged, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality, as it was before IC failed.
If after self or autofocus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
If convergence can not be adjusted properly, you messed up chip install or resistors may be wrong value or open; or it needs major adjustment.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Jun 06, 2008 | Samsung HCN4226W 42" Rear Projection...
New Convergence board but need help adjusting convergence still
If the new sub board didnt fix the problem you will need a new convergence board as the sub deflection boards with the ICs only powers the convergence board. thats a complete seperate board. Let me know if you need more assistance.
May 22, 2008 | Samsung HCM5525W 55" Rear Projection...
Convergence off
The convergence board is bad. If the convergence board were still good, then the convergence menu would allow you to adjust the crosshairs.
Mar 03, 2008 | Philips 51PW9303 51" Rear Projection...
Convergence problem
This convergence boar should be available from ptscorp.com. Go to the website, look up the telephone number, and call them and see what a new convergence amp board cost. Good Luck
Jun 15, 2007 | Samsung HCM653W 65" Rear Projection...
Convergence board replace, still cannot manually adjust covergence
Do you have everything pluged in?
did you get a new board or repaired board. I think it's defective if everything checks out
Apr 14, 2007 | Samsung HCN529W 52" Rear Projection...
Televison & Video Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
