Question about Kenmore Dryers
Turned drum by hand, heard loud bang. Drum will not turn anymore. How do I fix it?
    President:
  • Kenmore Master
  • 1,922 Answers
Your belt probably broke the bang evidentally was the pressure being taken off your belt tensioner when belt gave out take frt cover off then top cover both will need to be off to repl belt anyway if that was it
Posted on Jul 29, 2009
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Mar 26, 2016 | Samsung DV218AEW Electric Dryer
My whirlpool duet sport dryer made a loud bang then stopped working and now says its sensing,,what could be wrong
Try reaching inside the dryer and turn the drum by hand. There should be some resistance because of the belt going around the drum. If you can turn it freely my guess would be the bang you heard was the belt breaking and the idler pulley hitting the floor or the side of the dryer. Most dryers today will not run if the belt breaks because of a safety switch. Hope this helps.
Jul 23, 2014 | Whirlpool Dryers
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Loud banging noise looks like the drum is off set and it damaged the rubber in the front
If the inner wash drum is sagging when it is empty, it probally means that the support arms that hold the drum has failed. If you turn the drum by hand and if you hear any kind of banging noise or the drum wobbles more that a fraction of an inch, then the support or spider arms are broken.
You can't buy the spider arms seperately and must buy a drum and spider as one unit. The cost to repair would be in the hundereds. See the following link to judge for yourself if you want to fix it yourself or have it fixed. http://www.fixya.com/support/t4267953-spiderarm
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drum not turning properly
Sounds serious! If the drum is floppy, it probably means bearings on rear shaft.Or there may be something caught between the tank and the wash basket.Check for wire or similar caught in holes in was basket. Try turning the was basket slowly by hand to see if the banging happens at the same place......Nomess
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Eaton viking dryer model ED214W449 .Loud hum when you try to star
My Eaton Viking Dryer Model # ED214W449 was running, I heard a loud bang and realized the drum had stopped turning and won't restart. Is this a drum belt issue? Is it hard to repair myself. Where can I get the part for this. Thank you.
Mar 24, 2009 | Dryers
Hotpoint VTD00 Banging loudly once per rev
I think the bearing has gone in the drum !!!
Dec 31, 2007 | Dryers
Dryers Logo
127 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
