Question about Roper RS25AEXLQ Side by Side Refrigerator
Overload protection relay burned, installed a backup and the compressor runs only a minute or two and shuts off. Insufficient cooling. Thoughts? Thanks.
  • 4,059 Answers
That means there's a problem with the compressor requiring a tech to either charge or replace the compressor.
Posted on Aug 14, 2009
Compressor on freezer running but not cooling
Dependingmon the length of run time will determine the problem. If the compresser cycles on and off within a couple of minutes then you are looking at a bad compresser. If it runs for 5-10 minutes then cycles off, you have a plugged off condenser or dead condenser fan motor, in which case do not run the fridge until the motor is replaced and cleaned. If the compresser runs for hour or so with no cooling effect then you may have a plugged off cap tube which means a repair man will need to take care of that. If the compresser cycles every 10-30min with a little cooling in the freezer then you are looking at a bad thermostat. Hope this helps
Sep 09, 2012 | Frigidaire Refrigerators
Refrigerator is not cooling. Compressor comes on than off after 20-30 seconds
you need to replace the ptc overload relay replaced on the compressor as this component is getting weak and is cutting out,it uses temperature vs. heat to protect the compressor from a no start or when the compressor cant operate on the run windings and overheats,then this ptc overload relay cuts out the compressor to protect it,it will keep trying to start the compressor till the ptc burns out,it just unplugs off the compressor and a new replacement plugs back in
Dec 23, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
When i turn on my beer machine. It turns on and then makes a click noise and shuts down. No cooling at all anymore
What your hearing is the KliXon thermal overload tripping. The compressor is not starting and the thermal overload is trying to protect the compressor.
This can be caused by 3 things.
1. A locked rotor on the compressor. (bad news)
2. A failed PTC relay on the compressor
3. A failed run capacitor.
Usually a PTC relay and a run capacitor will bring it back to life unless the compressor is actually seized.
Thanks for using FixYa.
Kelly
May 20, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Refrigerator not cooling, compressor runs for 10 sec
you need to replace the "ptc-overload-relay" located on the body of the freon compressor as they supply all the incoming power to the unit,the compressor relay gets weak and can't stay "latched" to keep the compressor running,you probably hear a clicking sound from there too,all you need do is unplug the old part off the compressor and plug in a replacement
Apr 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Dec 17, 2009 | GE Profile PSC25PSWSS Stainless Steel...
Compressor shuts down every 5 minutes or so. filters are clean
Shut down of compressor is triggered by thermostat, or overload protection inside the motor compressor.If there is an ice accumulation sensing/low temperature caused by clogged air flow, the system will shutdown. The air con must have cleaning, or the thermostat is defective.If the shut down is caused by overload protection, there might be a clog on the system tubing or the compressor need replacement.In rare cases the start up device (relay or PCT) may also cause that trouble.
Aug 31, 2009 | Sharp Heating & Cooling
KitchenAid fridg compressor heating up
If the compressor is very hot, it sounds like it may be locked up. Is there an external fan next to it that is not running. this will cause the comp. to overheat, like a dirty coil, which it sounds like you checked out. There is a thermal overload on the compressor. Its underneath the little plastic cover that the wires go to. It protects the compressor from a meltdown. It also has a relay in there. If you have an amp meter you can check this by waiting for it to cool off and clamp it on one of the compressor wires.when it clicks on, If the amps soar over 20 very quickly, and then stops. Its a locked compressor and the thermal overload is cutting it out. If you don't have a volt/amp meter, then try replacing the relay as its pretty cheap. But I would bet on the comp. as long as the fan is running.
Jan 16, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Roper RS25AEXLQ Side by Side Refrigerator Logo
197 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
