Question about Janome Hello Kitty 11706 Mechanical Sewing Machine
My Babylock 6150 fell over and the spool pin ("shaft"?) is broken. I have an extra spool pin but this is broken at the machine. I can not even figure out how to use the extra pin that came with the machine. Is this fixable? It cracked and broke off at the machine where the shaft actually has some sort of spring action. Please help me to find where I may purchase a replacement part. Thank you, Iris
  • Janome Master
  • 11,452 Answers
You may be able to (very carefully) super glue the pin back on where it broke off.
Posted on Feb 01, 2018
    Top Expert:
  • Janome Master
  • 49,066 Answers
If the part you have looks like it has threads on it , then you need to unscrew the old broken one out of the case and put in new one .some were just a press in fit . use small drill to extract the piece
2 Suggested Answers
SOURCE: I left the spool pin
check with
Posted on Jan 24, 2011
Can't figure out how to fill the bobbin
hi Beverly.
you have not said what make and model.
but try this.
Always wind the bobbin before threading the machine and needle.
  1. Place spool of thread on spool pin.
  2. Slide spool pin holder/cap firmly over rim of spool to prevent thread from tangling.
  3. Push bobbin winder pin to far left if it is not already there.
More items...
Winding a Bobbin ' Singer Sewing
or try this.
How to fill bobbin for sewing machine
How do you fill a bobbin on a Brother sewing machine? Use only the included bobbin or bobbins of the same type (part code: SA156, SFB (XA5539-151)).
  1. Turn on the sewing machine, and open the top cover.
  2. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the. ...
  3. Remove the spool cap that is inserted onto the spool pin.
More items...
How do I wind the bobbin? ' Brother Search for: How do you fill a bobbin on a Brother sewing machine?
or you could go and look at this link to see if it helps you out some more.
igniter button for SUNJOY PH018PSS Google Search
Nov 21, 2017 | Sewing Machines
How to change the thread spool pin on babylock model esp
Depends. Some spool pins simply push in and snap in place, but as many machine brands existing, there are probably double the different spool pins available... If you order from one of the online vendors, they will probably be able to advise how to install it.
Spool Pin for Brother Baby Lock X59053051 Old X59053022 X59053052
SPOOL PIN Babylock ESL ESP Espire Brother CS8072 PC2800 PC3000 PC6500...
Mar 24, 2017 | Sewing Machines
How to replace spool pin on brother se 350 sewing machine
Is this a chromed metal shaft that stick straight up?
IF SO, the broken piece can be PROBABLY be unscrewed using pliers. Then you have the thread size, the piece, that you can take to a hardware store and get a long blot this the same threads.
The part can probably be found on the internet using or on eBay.
92results for Brother sew spool pin
Mar 18, 2015 | Brother SE350 Mechanical Sewing Machine
I have a brother 6000i. How do I utilize the extra spool pin?? Where does it go ?
bAttach the extra spool pin.
Put the extra spool pin in the hole on the top of
the machine. Put the second spool of thread
onto the extra spool pin.
See page 25 in owners manual.
Feb 25, 2014 | Brother CS-6000i CS6000i 60-Stitch...
How do you replace the spool pin on a babylock ellure sewing machine
Place the cone of thread on your right, at the back of the machine. Bring the thread up and behind the bobbin winder spindle. (where the bobbin sits) Place the largest spool cap on the empty horizontal spool pin and take the thread through the hole of the spool cap. From this point thread the machine normally. This and many other common questions are found on this link click here If you have any further questions message me back Thanks Rick
Sep 15, 2011 | Baby Lock Ellure
Spool pin broken fell into machine, managed to get it out. How to I replace orrepair it
They are available online for about $4-$5. I saw a metal one for $4. Or go to and order from them.
Feb 28, 2011 | Brother LS-1217 Mechanical Sewing Machine
I have a Babylock Denim Pro II and the entire mechanism that holds the needle just fell off the machine!! What the heck do I do?
Hey there,
This just happened to me last night, too! I figured out that it tightens back onto the shaft with an allen wrench. I found a tiny allen wrench in my tool box and it did the trick. Hope this helps!
Jan 09, 2011 | Brother LS-1217 Mechanical Sewing Machine
How do i replace the spool pin on my singer sewing machine model # 3314?
Two ways.. either put the new spool pin in the other extra hole to the left of the trap door on top OR take out the two bigger screws on the top cover that hold it in, also take off the knobs on the front sliders (patters selection) and remove the top over. Push the old pin out from the inside with nail or something simila and replace.. simple. Do you have an extra spool pin you can share?
Nov 05, 2009 | Singer Sewing Machines
Hi - I'm sorry you have been waiting for an answer to your problem. Can you tell me whether this was first time you used the cartrige, or has it been working up until now? Unfortunately, the cartridges tend to break fairly easily.
To determine whether your cartridge is broken, take out the thread and thread it again. The cartridge won't lock-in unless your presser foot is up and your needle is raised to its hightest position (needle threaders are designed to prevent damage, so they often won't work if the parts of your machine are not positioned properly for threading).
If the cartidge still won't engage, check the page in your manual that describes the parts that came with your machine - you should see a picture of a spool pin. Although the spool pin is designed to accommodate spools of thread that don't fit in your cartrige, you can use the spool pin all the time. Your manual describes how to install the spool pin.
Fortunately, you can purchase spool pins and replacement cartridges from several online sources, including eBay, and some Babylock Dealers sell them (the Babylock and Brother cartidges are interchangeable). I have the same machine, and I always keep an extra cartridge around. I can thread the extra spool while the other is sewing. When the machine stops for a color change, I just insert the extra cartridge with the next color, then thread up the empty cartridge for the next color. Speeds up your embroidery alot.
On Google, type in Brother Thread Cassette - you'll get lots of hits, and you should be able to find a cartridge for about $10.00.
If you have and other readers have time to rate my answer (good or bad), your rating helps me determine whether I understand your problem.
If you have more details about your problem or have additional questions, please feel free to comment. I can send you the instructions for threading the cartridge and installing the spool pin if your manual is missing. Just submit a comment - and I'll help anyway I can.
Cheers, Ginny
Jan 18, 2009 | Brother Disney PE-400D Computerized Sewing...
Janome Hello Kitty 11706 Mechanical Sewing Machine Logo
96 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
