Question about Polaroid PDV-0700 Portable DVD Player
I have this dvd player about 4 years, and now when i put dvd's in its trys to load then it says no disc, Spindle does not rotate Dvd. How do I fix it.
  • 790 Answers
Hi
in this case you have defective ribbon wire and pick up lens and this parts nedd to replace a new one.
Thanks!
Posted on Jul 13, 2009
Shows all disc as bad
if you have a dvd lens cleaner tried to clean it first. if still no disc error, look for the spindle motor if it is rotating while you are playing with a disc. if not, check for motor worn out at this time you will need to remove the cover to access the internal part.
Nov 02, 2012 | Polaroid PDM-0743 Portable DVD Player
My disc tray won't open the lights turn on and work but the disc tray just won't open. How can I fix this?
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
May 05, 2011 | Cyberhome CH-DVD 300 DVD Player
Screen reads no disc after loading even though a disc is in. Also sounds like there is rubbing when the disc rotates.
Hi. From what you describe it sounds like the spindle, the part you clip your disc onto, has been pushed down too far and needs to be pulled back up a touch, 2mm approx. images?q=tbn:and9gcsk5rvhv599ebybl98lpb6yljx3-4i0e_7adbhvdacrx2wbx_vs-w Image for clarification only.
Feb 19, 2011 | Mintek MDP-1760 Portable DVD Player
My Polaroid DVD player - Model # PDM0822BD player shows that a disc is loading however the disc does not rotate. It then stops saying "loading" and says NO DISC. I've had it for about 5 years and I love...
If the disc does not rotate it means there is something wrong with the power supplying the disc motor or the motor itself is defective. Try to rotate the disc motor manually, If its rotating freely then the problem is in the circuit that supplies the disc motor.
Jun 09, 2010 | Polaroid Portable DVD Player PDM-0822BD
Dvd player trys to read disc but stops with a HO7 message, worked fine last night, but we did put a dvd in to watch but something came on the tv we wanted to watch and didn't turn off dvd
HELLO
This is a motor problem. Here is what to do to put it right.
Open the disc tray and switch off the power, then remove the lid off the player. Locate the disc motor and where the spindle goes through the motor put a little WD40 or light oil (but not too much) or it will get messy.
Turn the disc motor a few times yourself and let the lubricant soak in. Leave it for about 30 minutes then try it again - and it should work.
This works in a number of cases, though I can't guarantee it will work for you. TRY IT! (:-)
Oct 14, 2009 | Panasonic DVD-RV32 DVD Player
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Accurian Portable DVD player
Dirty DVD or bootleg format on the content?
Mar 08, 2008 | Radio Shack Accurian APD-3955
Dvd not reading
The spindle motor magnets have started to flake, causing the DVD's to slip. like on a slip mat. You need to take the cover off and remove the flaky magnetic particles on the magnets that clamp onto the DVD's. You can put a very light coat of rubber cement on the lower magnet and let it dry completely, this should give the lower magnet/spindle motor some traction on the disc and get it spooling up in the correct amount of time.
Dec 02, 2007 | Mintek DVD-2580 DVD Player
No Longer Plays discs
You should try this site. It worked for me. Also after fixing you should try and remove anything that may be on top of the DVD as this seems to cause the issue. We have had our S35 for at least 4 years and today was the first time I got the error.
http://wiki.xdroop.com/gallery2/v/Random/0706_001/IMG00104.jpg.html
Sep 01, 2007 | Panasonic DVD-S35 DVD Player
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Polaroid PDV-0700 Portable DVD Player Logo
509 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
