FixYa.com
Tags:
NEC Internal 52x CD-ROM Drive
PCProfiler.exe problem
By Charlie - usenet poster
I built a new system to put XP pro on and mostly it has been a pretty good
install. However, when I shut down I am getting a box with the following
message, "pcprofiler.exe - .dll initialization failed.............the
application failed to initialize because windows is shutting down." The
system shut down ok and I don't get an event message error.   I have
searched everywhere on my HD and can't even find the file to see what it is.
Microsoft KB doesn't have anything either. Could this have anything to do
with the fact that I haven't activated yet? I am trying to get everything up
and running before I commit to the install.  Any help would be appreciated.
A. Pym
SYSINFO
XP Pro (clean install)
Abit KR7A MB W/VIA KT266A chipset
AMD Athelon XP1800+
512MB PC2100 DDR
Maxtor 6L020J1 20g 7200
Radeon 7500
SBL Value
NEC 52x CDRom CD3002A
3COM Etherlink 10/100 PCI (3C905B-TX)
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks for the help.   I found out what it what program it was associated
with and took care of the problem.
A. Pym
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
Whatever it is, it is not an XP file.  A couple things
you can try to see what it is:
Start->Run, enter in "cmd" (don't include quotes for
anything in these directions) and hit enter.
At the command window, enter "cd \" and hit enter.
Next, type "dir /a /s pcprofiler.exe" and hit enter.
This will search the drive that XP is installed on for
the file.  If it finds the file, note what directory it
is in, it might contain the name of whatever product
installed it.
The second thing to try is the following:
Start->Run, type in "msconfig" and hit enter (same deal
with the quotes...)
On the new window, click the Startup tab.  Look through
the Startup Item and Command entries for something with
pcprofiler in it.  If/when you find them, uncheck the box
next to those entries.  This will prevent them from
loading on the next boot, and hopefully should get rid of
your message.
Can you Help with these CD ROM Drives problems?
CD ROM Drives
cd rom for a206x
need cd rom for this model... Answer This...
CD ROM Drives
LG GDK 70
I am looking for LG GDK 70... Answer This...
CD ROM Drives
cdrom often lostii
i am having compaq presario... Answer This...
CD ROM Drives
cd drive
do you know thw dimensions for... Answer This...
CD ROM Drives
Message indicates the dvd drive...
I have a ccd-52X6D model star... Answer This...
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
