Question about Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio
Cobra PR4700WX one will not work
One of my Cobra PR4700WX is locked upthe keys / buttons will not work. It will recieve from the other will not transmit. Can't change channels.
Neto
  • 123 Answers
SOURCE: Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio
This radios has a Reference Xtal, dropping the radio, could cause that the xtal goes out of frequency, this means tha the radios has a frequency error and the range of opearatin seems to be reduced or even null. With out knowlegement and equipmente, there is nothing that you can do.
Posted on Nov 22, 2006
zeusfaber
  • 247 Answers
SOURCE: Brand New Cobra microtalk won't work!
Double check against all the instructions - in particular, make sure the batteries are charged according to "before first use" spec, that the volume is turned up, and that the squelch (if fitted and not automatic) is adjusted properly. If it still doesn't work, take it back to Wal-Mart. If the product doesn't work, there's no need for the packaging to be in good condition - it's not as if they'll be needing it to resell the goods to anybody else. A.
Posted on Apr 08, 2007
Benimur
  • 6966 Answers
SOURCE: Cobra PR4700WX -none of the controls work
Your concern might be a simple case of "the radio is in locked mode" which can be verified with the presence of a padlock icon in the uppermost row of icons.
If it is so, turn it off by pressing the Lock/Mode button for a couple of seconds or till you hear a double beeping sound and/or the lock icon disappeared.
If there is no lock icon and none of the buttons will work, try to do a hard reset by removing the batteries and try again.
If none of the above will be corrective, your unit may require the services of a qualified communications technician since the problem may either be firmware or touch pad/logic circuitry.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 06, 2008
Benimur
  • 6966 Answers
SOURCE: help
Hi again,
It would seem that you posted twice. As responded to in your other post, the manual is here.
Cheers.
Posted on Mar 17, 2008
Goofguyster
  • 379 Answers
SOURCE: I have Cobra pr4700wx Walkie-Talkies which a non-responsive.
Hmmmm maybe your keypad is broke or your radio is locked
Posted on Sep 14, 2009
No Auto Squelch on Cobra PR4700WX
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
Dec 24, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra 132 recieves good poor send
i would take it in and get a new diamond thats what it sounds like to me..
Dec 02, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
COBRA PR4700WX
Hello horndog78,
Your radio may be locked. You can confirm this by looking for a icon of a padlock on the screen.
To toggle the lock on and off hold down the LOCK/MODE button for a full two seconds until you hear a double beep.
Best Regards,
Ken
Go Ahead. Use Us.
May 02, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Help
Hi again,
Cheers.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
If you find that the LOCK/MODE button does not correct the problem, I have discovered that the microphone button on the inside has a contact patch mounted on the board. This contact patch is like a piece of scotch tape with a metal dot in the center this slides off to the side and leaves the MIC deppressed continuosly which in turn will lock the radio. I have found this on several radios. Once you center the patch place just a small amount of super glue to the edges and yo will have no more problem
Jan 06, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio Logo
200 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
