Question about Kenmore Sewing Machines
Hand wheel won't turn, needle won't move
Kenmore sewing machine has been working all day (on and off use) Suddenly slowed down, became much harder to sew, and then stopped completely (all within the space of six inches worth of sewing). Hand wheel won't turn, needle won't move.
  • 30 Answers
SOURCE: Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Posted on Jan 24, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 323 Answers
SOURCE: conse sewing machine...broke needle...put new
machine threads left to right and the hole is on the side. the long groove of the needle goes to the left.
needle must be 135x17
sewman7
Posted on Mar 20, 2009
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
Why is the wheel on the right hand side of my machine very stiff when turning
the "hand wheel" on a sewing machine is meant to only advance the mechanism far enough to thread and set the needle , the motor should be used to run the machine else wise , as its turning every thing inside the machine to keep all the functions in "TimE" as models increase in there complexity there hand wheels are harder to move as more stuff needs to be kept in "time" now , also on some models the bobbin winder is directly powered by the hand wheel , if its not in use it should be disengaged completely
Mar 02, 2016 | Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Jan 17, 2009 | White Sewing 1766 Mechanical Sewing...
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
