Question about GE JTP15 Electric Single Oven
GE ModelJTP14 oven, after 30 minutes at 350, the oven flashed a F2 code. Cooled and restarted the oven at 350, after 26 minutes it flashed F3. I have been remodeling and have taken the oven out of the cabinet, but did not disconnect the power or anything.
    Problem Solver:
  • 3 Answers
Check the codes for your particular model..they are included witht he wiring diagram that came with your oven. F2 likely means your control board (ERC) has an issue. I can't vouch for accuracy but here's another location with fault code listings http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes
You can try turning the circuit breaker off that feeds power to your oven ( in your house electrical panel) that might work. If it does not, unfortunately it might be indicating a need to replace the control board... good luck!
Posted on Aug 27, 2009
GE OVEN THROWS F2 AND F3 CODES SOME TIMES WORKS FOR 45 MINUTES BEFORE CODE
The F2 code means that the oven overheated by at least 100degrees(a bad sensor will cause that)
the F3 means that the oven sensor is shorted,so both of them are consistiant with defective oven tempature sensor and the sensor should be replaced.
It is located in the oven baking chamber and can be replaced by unscrewing the screws from the bracket at the end of,pull it out unplug it,then reverse that process to install the new one.
With 2 different codes pointing to a bad sensor its apretty safe bets its bad.
GENE
Oct 10, 2011 | Ovens
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
GE JTP15 Electric Single Oven Logo
316 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
