Question about JVC RX-6042 Receiver
Sound cutting out
If I'm listening to the radio or whatever the sound will cut out from time to time.
I have resoldered the 2 large caps and some other joints that looked suspect but it had no change.
Thank you for your time.
  • Pratt985 Dec 21, 2007
    When surround shut off the sub will turn off and on and with surrond on all speakers shut off and on.
  • vegwagen Mar 06, 2008
    Same Crap Here! Some Help Please!
  • 3 Answers
Sub should work as long as u don't have the reciver on digital it should still work ur mains and the sub but no sound from the rears, the radio cuting out could because bye a resister failing it might not have burnt out yet but it is not working proprely if it only happens when the radios is on try to see if local stations come in clear with no antena . but if it happens when the reciver is on tv or another input take to ur closest repair shop to be fix or u might fry the mother board happen to one oif my old recivers.
Posted on May 19, 2008
Left channel cuts out, if i tap the reciever it will come back on.
sounds like the controls are dirty...or possibly the solder connection on the volume control has become can goto your local electronics store(or Radio Shack) and get some contact the unit up and clean the volume control as per the instructions on the can...make sure when you spray the cleaner into the control you turn it back and forth several times...then you want to spray more in to flush out whatever debris may have been in careful not to get any on the face plate as it may damage the finish...also , make sure that the chemical spray that you use is safe for plastics...If this doesn't fix it , then the volume control assembly may need to be resoldered.
Mar 01, 2012 | Sony STR-DE185 Receiver
1994 Cadillac Fleetwood Radio. Once turned on the display cuts out, you can tune the radio to a station. The problem i'm having is that the radio will go from low volume to very high and then cut off...
Most likely, you will have to remove the radio
& take it to a car radio shop
Not many around anymore
They usually resolder whatever & put a
new belt on your Cassette or CD Drive & your good to go
Aug 03, 2011 | 1994 Cadillac Fleetwood
2000 nissan quest: Ran out of gas will not start.... no spark from sprk wire????????? help before i get charged by service station at $90.00 an hour....Thank You
Not a professional, but what i would do is...if you filled the tank up again.....get someone to turn the key a head (don"t start it) just a head to when the radio comes on .....when they do it a few times(a head and back to off) stand back by the fuel tank (gas cap area) and listen for the pump to cut in! It should only cut in for a few secs. If no sound, you may have burned out the could have sucked up dirt and burned out! Thats my guess!
Dec 22, 2010 | 2000 Nissan Quest
My Sanyo TV was plugged in, I was watching it and all the sudden the screen went gray wash, then it cut off. You can plug it in the wall and it will try to cut on but cuts off after like 2 seconds. It also...
U have a soldering iron,solder?Now basic soldering?Unplug the tv wait about half an hour for the highvoltage to disapear.Take the tv aparts.Resolders the Video board that connected to ur CRT Tv tube.Resolders all those coldsolders pins sockets pins on the video board,will solved this problem.Have fixing these problems many times on the CRT Tube computer monitors,when it was still popular.
Sep 09, 2010 | Sanyo Televison & Video
Radio and display cutting out
fuses and the elctronic tec u need > to reset or the panel had been sprayed with fluid .
i had same case with BMW .
Apr 15, 2010 | 2002 Dodge Neon
Tv pops then cuts off
The right direction is right to the service center! you have a failing transistor that could catch fire.
please rate our help so we stay on the net
Aug 17, 2009 | Pioneer SD-532HD5 53" Rear Projection...
No sound when radio is turned on
i have the same problem with mine..did u ever find out how to fix it?
Jun 04, 2009 | Sony MHC-GX450 CD Shelf System
Radio cuts out
yes it sounds most likely like an ant amp, and it is not that hard to replace, the best way to determine it is a new one since it is intermit, it is located in the C-pillar i think on the pass side but i could be wrong all you have to do is remove the light from the trim piece detatch the top part the pull up it sits in a groove, looks like a small white plastic box
Mar 24, 2009 | 2003 BMW 325
Radio cuts out
hello ,.this could be a bad antena amp it is located in the c pilar left side of vehicle /( if it just started to do the problem ) what i mean is that this is not a new vehicle that you recently got /or the radio are is wrong ,the bmws come with international radios that you can change the different waves of singnals to the same radio ,example if you move to japan you can use your radio in japan / to do this press the mode button and hold it and it will give you the diferent ptions . good luck
Nov 20, 2008 | 2001 BMW 5 Series
JVC RX-6042 Receiver Logo
293 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
