Question about Toshiba TP55F80/81 55" Rear Projection Television
When you turn the tv on it turns itself right back off
  • 979 Answers
Problem with the power supply board. check the regulator. voltage out. if you cant do it. visit you local service center
Posted on Jul 13, 2009
I go to turn it on and it sizzles and shuts itself off.
Replace the flyback. You need the 259296 flyback replacement kit which has the flyback related capacitors and the CD with detailed instructions. The kit is available at www.tvrepairworld.com
Sep 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
Feb 02, 2009 | Televison & Video
Mitsubishi WS 65513 turns itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
TV shuts itself off
Mine does the same thing , too. I turn it on and off repeatedly , but nothing happens.I unplug it to see if it resets and nothing still .
Aug 02, 2008 | Mitsubishi WS-65908 TV
Tv unexpectedly powers off
Hi i has the same probleme..... My tv has 1 years and 6month... since two days.... the tv turn off itself...I have just take 15minute, unplug tv, and i have open in the right side the little panel...And i have clean inside!!! And i have do the same thing with the big panel in the back of the TV...After i have clean the fan...After this clean my tv is number one... and nothing turn off
Apr 21, 2008 | Toshiba 42HM66 42" Projection HDTV
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
TV Problem
SANYO MIGHT HELP YOU BUT YOU NEED TO CALL IMMEDIATELY BEFORE MORE DAYS GO ON..
Feb 21, 2008 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
