Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Water gathering on top of fridge like water droplets i have to dry it up every other day
  • 4 Answers
Check to make sure that your seal is tightly fitting. Do this by taking a piece of paper and close the door on it near the seal around the door. You shouldn't be able to pull it out. If you can, replace the door seal. There's too much moisture from a bad seal. Hope this helps.
Posted on Jul 13, 2009
FRIDGE
Your fridge is making condensation check the doors if it's closing properly I think the fresh air is going in side
Sep 06, 2014 | Smeg FAB30 Top Freezer Refrigerator
Why does water in the fridge keeps accumulating
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents into the fresh food area. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. You may want to place a small tub in the top shelf to collect all the water that will pour through the vents and have some towels. it can get very wet.
Some models have a drain collector in the control panel assembly at the back and this runs into a drain grommet. this collector can plug up. You will have to remove this and clean out the collector tube.
I have found that some Frigidaire and some of the Kenmore refrigerators made by Frigidaire have a problem with water droplets accumulating in the air duct and when it defrosts thee droplets run down and drip into the fresh food section.
Aug 15, 2014 | Refrigerators
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water in fridge
does this fridge have a gulley at the back with a drain hole in the middle? if so, the drain is blocked, push something flexible down the drain till water flows away freely
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Dried water droplets on inside of lens
The camera lens will have to come completely apart, and all the pieces be cleaned. This is not something you can do yourself at home. Because there is water in the lens, there is the risk that the humidity will cause corrision of some of the pieces and electronics inside of the lens unit.
You an try leaving the camera in a dry warm place that is not more than about 100 deg F for a few days to see if the water will dry out. But, I am sure that there will be water stains inside on the lens surfaces.
Jerry G.
May 16, 2008 | Olympus Cameras
Refridgerator problem
your defrost is not working it shoud defrost auto.
Feb 07, 2008 | Refrigerators
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
62 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
