Question about Sony Playstation 3 (PS3) Console
Hd out put will not work on PS3
The line to the tv doesn't show anything and now the sound doesnt play either.
    Problem Solver:
  • 4 Answers
Turn the ps3 off manually by holdin the button down. once it turns off n the red light appears let the button go then push n hold it again for ten seconds or so. Did u recently switch from component to hdmi?
Posted on Jul 13, 2009
Why doesnt my hdmi cable work from my ps3 to my evesham hd ready tv
Does anything else work on your TV through HDMI?
If not, your TV needs a new main board.
If so, does your PS3 work on any other set that has HDMI?
If not, you PS3 is bad.
If it does work, then it is a hand shaking issue between the two products that unless Sony has a firmware upgrade for, the two will not be compatible.
Apr 10, 2012 | Televison & Video
My problem is earlier today i was playing my ps3, the picture was showing on the t.v. ( a HDMI Cable conected it to the tv), but 30 minutes later, i tried to play my ps3, the picture was not showing up...
Sounds like your video settings are wrong. Since you were on the HDMI connection the video was outputting in HD. When you switched over to normal AV (composite) cables the video was still outputting in HD.
Simple fix: power off your PS3 (so it's in standby; red light is showing). Then turn it back on, using the power button on the console (not the PS3 controller) and hold down the power button until it beeps a second time (about 5 seconds). The video settings will reset to composite. If needed, change your video settings.
Normally I'd put down like 3 other things it could be (each worse than the last), but I'm fairly certain that this will fix it. If it doesn't, just say so and I have many a more potential fix available.
Hope it works!
Sep 24, 2011 | Sony Playstation 3 (PS3) Console
The ps3 is on and working but will not show anything on the tv
that sounds like a connection problem. check all the wires to make sure they're connected properly. if that doesn't work, then you need to change the settings on the console itself. ie. if you're using an HDMI cable to connect to the tv for example, that option needs to be selected in the play station settings... the problem is that you cannot see what's on the screen.. is there anything else you can connect the ps3 too? or can u use the cable that came with it to connect it t the tv?
Aug 19, 2011 | Sony Playstation 3 (PS3) Console
Ps3 not wworking on regular TV after hdmi cable was used.
sounds like you have the ps3 set up in HD video display settings?
If this is the case hook it up to the regular tv and when you turn the power on continue to hold down the power button til it beeps this restores the video to default settings sometimes it takes a 2nd power down and power up holding it down to work.
If this doesnt solve please give more details
May 02, 2010 | Sony Playstation 3 (PS3) Console
Doesn't recognize non HD TV
hook your PS3 to the tv with the regular cord, put the tv on the channel you want. with the PS3 off but switch in on press and hold the power button until it beeps twice then release. you can also do this the other way round (SD to HD).
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
My ps3 doest display anything nor makes any sounds please help
Just a gander, but your PS3 may be set for HD output thus not displaying on your non HD television, your best bet in this case is to find an HD television, friend, coworker, etc, connect to it and switch the settings back to regular. Also if I understand correctly leaving the ps3 completely unplugged for 72 hours may also reset all settings. Good luck!
Jul 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
PS3 no picture and no sound
Try turning the system off completely with the main power switch on the back of the console. If that doesnt work call Sony technical support for further help.
Aug 04, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
What tv do you have:
lcd full hd or hd ready
plasma full hd or hd ready
normal tv pal analog 60 hz
Jun 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
