Question about Refrigerators
The ice maker in my Kenmore is not making ice, but is leaking water down the freezer, creating icicles everywhere. Should I just replace the ice maker? Is it hard to do?
  • 520 Answers
No. Replacing the ice maker is not that hard but that is not the problem. You acutely have two problems. The first of witch being that you have terrible water conditions where you are. The second problem is caused from the first. The solenoid valve that feeds the ice maker is damaged from the contaminants from the water and is allowing water to trickle through this valve. This is why you have ice cycles. Have the ice maker solenoid valve replaced and install a filter in-line before the ref. This should take care of the problem and get you back in business. Hope this helps. Good luck. please re-post with updates. Thanks cj2176.
Posted on Jul 13, 2009
My Kenmore refrigerator's ice maker is dripping at the front of the ice maker. it drips slowly but makes a big chunk of ice right at the front of the bucket. What should I do?
This is pretty generic without a model # but holds true with alot of them..this type of icicle is usually caused by water overflowing the ice mold of the ice maker module. The reason for the overflow could be that the ice maker module is not level. Check to see if it is tilting. This could be caused by loose screws or a warping of the liner on the side wall of the freezer.
If the ice maker is level, then the next cause could be that the ice maker is overfilling. There is an adjustment screw on the right side of the front of the ice maker module. You may have to remove the cover from the front of the module to access this screw. Turn the screw counterclockwise to decrease the water fill. Turning this screw one turn may decrease the water fill level in the mold enough to prevent the leaking. If not, you may need to make a second adjustment.
Other problems that could cause this icicle could include:
Wicking of the water over the top of the ice maker mold caused by hard water deposits in the mold.
Leaking of the ice maker water solenoid valve.
Crack or leak in the ice maker module.
If the module is level and decreasing the water fill level does not solve your ice maker problem, then I recommend checking the ice mold for hard water deposits. If you find no deposits in the mold (or clean them and still have the same problem), then you will probably need a service technician to fix the ice maker. if you need more help, re-submit your question with additional details.
or reply in comments.
Jan 02, 2018 | Kenmore Refrigerators
My whirlpool gold ice dispenser leaks water and creates icicles inside, what could this be?
bad water valve or the ice maker is cracked,if the valve doesn't work correctly it can let to much water into the ice maker causing it to overflow or the ice maker has a crack in it and the water leaks out.
Jan 23, 2013 | Whirlpool GS6NBEXR Side by Side...
I have a Kenmore Coldspot refrigerator with top freezer. The icemaker is "leaking" if it is the right word into the ice tray bin that it is building a chunk of ice along with the regular ice...
There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
When it Won't Make Ice
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice.
The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
When the Ice Maker Leaks
1 Refer to your user manual to determine where your fill volume adjustment dial, is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
2 See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician.
3 Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
Thanks have a nice day!
Sep 05, 2011 | Kenmore Refrigerators
Water leaking into refrigerator from freezer
1. Refer to your user manual to determine where your fill volume adjustment dial, is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
2. See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician.
3. Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
I hope this would help.
Thanks have a good day : )
Apr 12, 2011 | Kenmore Refrigerators
My ice maker in my freezer calls for water and water flows for about 20 seconds and overfills the tray and then water runs down in the ice bin and down inside the freezer. It is a Kenmore SXS from 2000....
1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
Hope this would help you.
Have a good day : )
Apr 08, 2011 | Kenmore Refrigerators
The ice maker does not work. I can hear the water running sound, but it leaks out somewhere and runs under the refrigerator somewhere and out.
Hi
Refer to your user manual to determine where your fill volume adjustment dial is and turn it down. One-half to one full turn usually is approximately equal to 20 to 40 cc, and the correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician. Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
The icemaker stopped making ice. There is water supply to the water dispenser, its a separate outlet. The Refridgerator is made by Kenmore in 1997. I took the modular ice maker out and looked at it...
1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
Hope this tips could help.
Have a nice day : )
Mar 14, 2011 | Kenmore Refrigerators
Kenmore Ice Maker ice freezes solid in catcher - I think there may be a leak in the foremost line because icicles form on that side. I have extra line - is it complicated to replace?
The solenoid valve that lets the water from the supply line when the ice maker calls for it is leaking ,it's located in the back of the fridge at the bottom behind the cover where the water line goes in.It's very easy to replace (before do anything remember to turn off the water).
Aug 04, 2009 | Freezers
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
