Question about Estate TGDX640JQ Gas Dryer
Dryer ran all night now no heat
I have an Estate TGDX640JQ Gas Dryer (Estate-Whirlpool). my wife noticed yesterday that the dryer was still running this morning hours later than when she turned it on the night before. The timer didn't move as it usually does and I noticed there was no heat in which to dry the clothes. Once changed to a different cycle the timer worked and the dryer does run and tumbles the clothing but, no heat. Do you have any suggestions and, if so, is this worth repairing?
  • dsmoove91 Jul 13, 2009
    After taking apart the whole dryer and checking the burner assembly i found no burned out or fouled out parts. I put the dryer back together and left the back panel off pluged it back up and started it up the burner came on for no more than 1 minute then went off. At that time I removed both thermostats from the burner housing but still attached to the wires and started it again it stayed on. So the answer is u need to change the thermostats. To check and make sure just pull off the back of the dryer an remove the thermostats from the burner housing then start this sill be tour answer and the piece is about 25.00 good luck an God bless.
  • 547 Answers
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
2 Suggested Answers
SOURCE: No heat
What I learned is that the fuse needed to be replaced on the dryer. The back had to be opened in order to reach any elements, but the service man replaced the fuse and my dryer now works again.
Thanks for the suggestions.
Posted on Feb 08, 2008
Hello, My dryer is turning however there is not
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Estate TGDX640JQ Gas Dryer
No heat
heatman101
Mar 29, 2011 | Estate TGDX640JQ Gas Dryer
Everything goes on, just no heat with my gas dryer.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 30, 2010 | Estate TGDX640JQ Gas Dryer
Will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 25, 2010 | Estate TGDX640JQ Gas Dryer
Whirlpool Estate gas dryer dries but has a loud rattling sound when its in operation.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 11, 2010 | Estate TGDX640JQ Gas Dryer
Dryer runs but does not heat at all
heatman101
Aug 03, 2010 | Estate TGDX640JQ Gas Dryer
I cant lite the pilot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Estate TGDX640JQ Gas Dryer
No puilot on.
U must rmove the whole front of the dryer to get to the pilot. Good luck.
Oct 17, 2008 | Estate TGDX640JQ Gas Dryer
Timer doesnt move while dryer is on
Please page me here so that i can get back to you
May 19, 2008 | Estate TGDX640JQ Gas Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Estate TGDX640JQ Gas Dryer Logo
925 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
