Question about Plumbing
Reverse osmosis faucet is leaking through the aerator on the back. I does it whether the water is on or off. Any suggestions?
  • 297 Answers
When was the last time you checked the filter,it may be time to change it,if you have changed it you may have inserted it backwards.turn it over and try,if that still does not work the check valve at the filter feed line may be clogged,flush line this may fix your problem.good luck with your project.
Posted on Jul 31, 2009
I have a Nicolozzi Faucet Monterosa style and the hot water handle is loose and there is no water flow. The cold water handle is fine and there is good flow from the cold tap. I need to know how to ta
Determine which side of your faucet is leaking by shutting off the water supply valves one at a time. If the leak doesn't stop after the first valve is turned off, it's the other line that's leaking.
Once you determine which side is leaking, turn off both supply valves.
If your valves are stuck, shut off the water main. You will have to replace hardware for both sides since you won't be able to identify whether the hot or cold side is leaking.
Disassemble the Old Faucet
Step 1
Turn faucet handles to the "on" position to release any residual water. Close the drain and place a towel in the sink to protect the surface and catch any dropped parts.
Step 2
Remove the aerator and inspect it for damage. If it's stuck, soak a towel in vinegar and wrap it around the aerator to help loosen mineral deposits. After an hour, gently twist the aerator with a towel and pliers.
Step 3
As you disassemble the old faucet, lay the parts in order on a flat surface and snap a picture for reference. Then, put those parts in a plastic bag and take them to the store with you when shopping. You may only require one part, but it may be best to buy a kit and replace everything, including a new aerator if yours is damaged.
Feb 02, 2018 | Plumbing
Salt taste in water
If you're getting salty water from a reverse osmosis permeate line, that means the ro membrane is ruptured or the membrane o-ring is deformed.
Replace the o-ring and if that does not solve the problem, replace the membrane as well.
Mar 10, 2014 | Fleck Water Dispensing & Filtration
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
Water filter system leaks at tap
The line from the faucet to the drain was plugged. I cleared the line and the system is working well.
Apr 14, 2009 | Plumbing
I am getting slimy film floatys in water from my reverse osmosis system. I just changed the sediment and activated carbon filters.
When you replaced the cartridge did you by chance clean out the unit before putting in the new one? If not, then this is where it is coming from. I would suggest that you take it apart again and make sure that it is clean inside. This slime build up in the filter is completely normal and may also indicate you waited a little too long to replace. It also depends on the type of water you have as well.
Apr 10, 2009 | Dmm Designer Water Filter Reverse Osmosis...
Changed filters on Whirlpool Reverse Osmosis and now water leaks.
the tube going from the ro cartridge is clogged or the drain tube going from the faucet to the drain p trap is clogged
I have installed many ro systems a=nd have had that problem Not only do youhave to replace the filters but make sure the drain hoses are clear
use a pipe cleaner or a a stiff wire
I also remove the connection going into the ptrap and clean back to faucet...it is usually real nasty
Dec 29, 2008 | Plumbing
Plumbing Logo
755 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
