My window air conditioner sounds like it has a few small pebbles being whipped around inside - not consistently, but I wonder if there is a safety issue. i like to leave it on when i am not home so i can come home to a cool apartment but it worries me. anyone know what's going on? it's a goldstar. thanks
  • ingrid_graud Jul 13, 2009
    thanks! sicne i did't want to take it out yet to check the back, I took the pre-filter out to vacuum it and saw there was a lot of frost in there - i think cleaning the pre-filter helped get that melted. it seems quieter. thanks!
I would say the sound you hear is ice being thrown around and then it just melts back into water...is your A/C draining the water correctly? If you can open the back of the unit and look to see if anything is broken inside (wear safety glasses) and check the drain to be sure that the water is not collecting and then turning into ice
Here are some different solutions:
http://www.associatedcontent.com/article/33767/how_to_fix_a_noisy_window_air_conditioner.html
Posted on Jul 13, 2009
No heat but fan is working
If you're comfortable working around electricity then you might try trouble shooting a few things. Most HVAC (heat, ventilation, air conditioning) systems have a window which you can view the circuit board and a blinking led light. The number of blinks corresponds to the error code that is occurring. Some models have an explanation on the inside of the removable access panel. A few things to check for: Does the ignitor glow on start up? If not, the blower will start but then shut down. No glow, no ignition, the safety feature will not allow gas to flow. At that point, check the ignitor, it will be the cheapest to replace. If it glows, I would then check the sensor probe. If the sensor probe does not detect heat (or it went bad) then gas will be shut off for safety. After that, then I would move to checking the Controller Board. This is a little more involved and more expensive. But it really depends on how adept and handy you are. Good luck.
Nov 25, 2013 | Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump...
Hi I am waiting for the gas fire installer to re-visit my home regarding a Paragon slimline 3 gas fire. The problem i am experiencing is the pebbles keep slipping down and I have to keep re setting them....
Unless you just have to have the "Pebbles" look, I would suggest changing it over to the "Coal" look, as this is an option. Rather than having individual coals, they are formed into one piece. Therefore, they will not slide or pop out like the pebbles do,
The popping out may be caused by delayed combustion. This happens when gas builds up under the pebbles and finally ignites in a big, whooshing type explosion. Which can cause the small pebbles to pop or slide out of the firebox.
Hope this helped solve your problem. Please let me know.
Mar 14, 2011 | Heating & Cooling
How do I gain access to the fan which is located on the inside of the unit of a split aircon, the unit which resides inside the house. Need to pull this part out off the unit to clean it. Thanks
is this a split system on your wall or a cassette(a square unit in the middle of the room) like in the picture? units on the wall are very annoying to get out and if you do you will probably brake it. best to just turn of the unit and whip and spin whip and spin with a long brush or stick with a cloth on it.cassette units you unclip middle filter plastic panel then theres a fan use a shifter to undo ?
Oct 29, 2010 | Cfm Daikin R410a Split System Air...
My air conditioner delivers cold air only in spurts. It then goes into fan mode for a few minutes, then to cold air in a few more minutes. It is over 100 degrees outside and the inside of the house is 85...
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up
The unit will need to be recharged or replaced...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 27, 2010 | Fedders AED24E7F Wall/Window Air...
Hi - my ac unit is really loud...sounds like an airplane taking off....it is not a consistent hum, it's constantly reving up and down
Need more info here. Where is the noise coming from? The inside unit (furnace or air handler section), or the outdoor unit?
Or is it a window unit or other self-contained system?
Sep 04, 2010 | Heating & Cooling
WATER LEAKS FROM ALL OVER ON THE BOTTOM OF AIR CONDITIONER.WITH THE WINDOWS I HAVE, I CANNOT TIP A/C TO DRAIN OUTSIDE.WITH THE WINDOWS I HAVE, IT JUST UPRIGHT IN THE WINDOW. IT ALSO ICES UP A LOT. THANK...
Air conditioners MUST be tilted to drain. If not, they will drain into the room. Try shimming up the inside of the window sill with a few thin boards. The ice problem is either because it can't drain or, it is too small for the area being cooled.
Aug 03, 2010 | Heating & Cooling
Does the product a/c have a drain hole?
Air conditioners of your type have tiny passages that allow the water (if clean) to go to the back of the unit where a splash ring on the fan blade whips the water onto the hot condenser coil, eliminating the condensate outdoors and subcooling the refigerant in the condenser in doing so.
If you have water inside and its level or slight tilt back , then you need to clean it up or forget it!
Aug 25, 2009 | Fedders A6U10W7A Thru-Wall/Window Air...
Our central heating unit will come on and then off within a minut
If it shuts down completely, it is probably a safety device. Doubt if it's the t'stat. This sounds like something is overheating and the safety is shutting down the unit. The safety could be the fan delay/limit switch. Also, there are usually several "Thermal Disc" type safety devices located near and around the heat exchanger. These can go bad. In other words, they can "Trip" at a temperature lower than the rated temp the devices is supposed to trip.
I would look here for you problem. Good Luck
Feb 21, 2009 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
