Question about Iomega Silver Series (33213) 160 GB Hard Drive
Damaged usb I dropped my hard drive with the usb plugged in and have broken the solder joint(s) so I can't access my movies I am editing and need to finish to earn $$$ and pay my rent! I have unscrewed back and pulled drive out of casing I can see the card the usb plug should be soldered to How many points will I need to solder and how do i go about it. It looks as tho I will have to unplug the ribbon (or whatever u call it) and power plug from the drive, undo 4 screws holding drive in place, possibly undo front of iomega and take out hd. then undo screws holding card down to remove card and heat 2 joints from back of card. Is that right - are there any special tricks I should know? Do I need to put solder in or should heating existing solder work? The  power looks ok and the rh of the 2 light indicators goes green when I turn iomega on. I can't recall what light(s) should go on or where my manual is p/n 31460000 LDHD160-U
  • haywoodfarm Nov 17, 2007
    When i dropped it it fell of a low chair onto carpet landing on the usb cord - it was also in a bag. So I am hoping the drive is ok and its only the usb plug joint that is damaged so would still appreciate helpful answers to my questions
  • 84 Answers
If its a hardrive and you dropped it . theres a chance that the drive is broken because of the impact .. drive platters are sensitive
Posted on Nov 16, 2007
  • boogie yu
    boogie yu Nov 17, 2007
    i dont get what you mean with the solder joint. sorry i cant help you
My USB broke, is there any way I can access and trasfer my files, even if it means going inside the device?
The circuit board maybe broken or the USB plug needs resoldering back onto the circuit board. To check out the damage the circuit board needs to be removed from the casing to check for and circuit board damage or damaged solder joints. You need a fine tipped temperature soldering iron for this job.
The damage may be too great to repair.
It pays to backup your data in two sources in case one of your data drives fails.
Apr 17, 2012 | Verbatim Drive USB 20 16GB Store n Go...
I dropped the external drive and now when I connect it to a computer it doesn't show up
It seems that the internal connection on your external HDD has been broken. Kindly do not tamper with it yourself or else it may damage the pcb through which it is connected. If it is under warranty kindly contact the OEM for replacement. If not then take it to a repair shop who is in possession of quality soldering skills so that he can resolder the joint.
Jan 19, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
750GB My Passport Essential SE was working fine. Today I took it out of its case and plugged it in to my PC. Light came on for a bit, then started flashing. It did not appear on my Desktop as usual. Not...
If the drive is not spinning up, then you may have a damaged pcb, Have you tried this drive on another system. If your drive uses the mini USB connector. I have found that the solder joint is not soldered properly, I had the same issue, then upon soldering the connection USB connector at the pcb of the enclosure( not the drive) this fixed the problem. Let me know what you find, Dennis Sigala Computer Design Technologies, LLC
Jan 10, 2011 | Western Digital Passport WDXML800UE...
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital My Book Essential Edition 1TB Hard Drive I drop it and broke the USB connection. I connected it internally but it is being found as a non formatted drive. How do i recover the data?
It would appear the the shock not only damaged the USB connector but also the drive. You could try Hirens.BootCD and carry out a RAW recovery and you may be lucky and recover some of your lost data. If not then it will be gone forever as you have damaged the plates inside the hard drive itself
Jul 20, 2010 | Western Digital My Book Essential Edition...
Dropped it want read
First off....most people don't like to answer these posts because nobody wants to hear that the drive is most lilely broken and the data lost...the fact is, these external hard drives or any hard drive for that matter are not built to be dropped unless they are built to military with that said, there is the possiblitiy that only the interface between the external case and the hard drive itself has been damaged. There is a small plastic circuit board inside the enclosure that houses the SATA connection of the hard drive with the USB connection of the enclosure. This interface allows the hard drive to communicate externally with any computer. These little circuit boards are very fragile and are usually the first things to go when something bad happens. The drives themselves are fragile but not as much as the interface. What I would suggest is that if you need to get to your data....disassemble the enclosure and buy a SATA to USB hard drive adapter at a computer retail store and attach the removed drive to the adapter and plug it into a usb port on the computer. The computer will then power the drive through the usb port and if all goes well will recognize the drive and display the drive under the "My Computer" icon. You can then access your files. To disassemble the My Book, look for a small circle on the side of the case, on one side is a sticker that covers an attachment screw. Remove the screw and then on either end are catchment teeeth that have to be disengaged from the mounting try inside the enclosure. The outside of the enclosure slides open from the rest.
May 24, 2010 | Western Digital My Book Home Edition 500...
I dropped my Western digital 1TB hard drive.
The case maybe damage, so could the hard disk.
First try connecting to your computer or to an USB hard drive adapter, if it works then you know the hard drive is OK and you only need to buy a new USB hard drive adapter case.
WinHex is a edit program that allows to you see and modify the data files on the hard disk in ASCII and HEX format. If the hard disk is faulty no programs can access the data on the hard disk.
There are data recovery companies that can recover data from damages/faulty hard disk BUT it will cost you an arm and a leg for their services.
Sep 20, 2009 | Western Digital My Book Essential Edition...
Arogsy 500GB HD Drive won't boot up
If you have dropped it, most likely the hard disk is damaged, especially if it makes clicking noises..
The case is probably screwed together, but the screws are hidden with plastic covers or under a label.
If you are able to remove the hard drive you can connect the hard drive to an USB hard drive adapter and conect it to a working computer's USB port. It will see it as an external hard drive, if the hard drive is OK you can view and open the folders and files.
You can also connect the hard drive to a desktop PC as a slave drive if the PC's BIOS can support a hard drive of 500Gb.
If you are desparate to recover data from a damaged hard drive, there are companies that can recover data from these drives BUT it will cost you an arm and a leg for their services.
Sep 09, 2009 | Western Digital 500GB My Book World...
take the hdd out of the external case & connect to another external case and try working it from there.
You can buy usb connection kit or a hdd dock from most puter part outlets or ebay for few $$
you most probably damaged a board inside you external case that might need soldering/repair/replace.
good luck, hope you get the info.
pls keep me advised if all works out
Apr 12, 2009 | Western Digital My Book Essential Edition...
Cruzer micro 4GB, unreadable in USB ports
sounds like your USB connector of the flash drive is damaged. Could be a loose/broken solder joint, or one of the pins on the USB connector could be damaged.
If it was my drive, I would open the case, solder a new connector on the board and backup the files.
Nov 09, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Iomega Silver Series (33213) 160 GB Hard Drive Logo
506 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
