Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic PT-53WX42F does not turn on, gives single flash code
I have a PT-53WX42F that I got broken for free 2 years ago, but fixed it by replacing the convergence IC's (it gave 3 flash code at that time). Today it failed to start and gives a single flash code... I understand this is the +140 section, but I cannot identify that on either circuit board, and I see no visible damage. Any suggestions on how to proceed?
Thanks.
  • 3 Answers
My tv had the same problem and the B+140 was low. When I measured it, it was 89volts unfortunatly led me to the Flyback tra$former. after alot of troubleshooting work, I realized that the primary is short circuited. Also the horizontal output xsitor heats up alot on start up, thankfully it doesn't blow :)
I've had panasonic flybacks do this before to me. I havn't replaced my Flayback yet but when I pony up the $65.00 I expect (and pray) the TV to work fine. There is an off chance that something like the splitter or the foucus block caused this failure, but I doubt it.
Posted on Oct 05, 2009
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
PT-53WX42F Panasonic Cinemavision Fresnel / Lenticular screens for cheap
That was an expensive mistake, sorry to hear about it.
I checked with the factory and not all 3 parts you need are available any more... Unless you can find someone junking a similar set with a bad chassis, you may have difficulty fixing your's.
Good luck in your search.
Mark
Nov 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Screen will not come on
Can you tell me how many times the light flashes or is it constant flashing/ It should flash a number of times, pause then flash all over again. Let me know what its flashing.
Jan 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT= 53WX42F
Does it blink three times if so its a convergence problem -your set uses stk392-110 i usually replace with stk392-150 or stk392-180 these are more stable. if you have no soldering experience or electronic experience. but if you want the challenge go for it. remember that there can be several thousand volts in this set even when unplugged.
Dec 12, 2007 | Panasonic PT-56WX53 53" Rear Projection...
Real projection tv model# pt-53wx42f
you need to replace (2) STK392-110s some are 120s 150s up grade to 180s.Also after you replace them you will have to do complete alinement of convergence in order to do this you must have service codes.
Dec 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
337 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
