Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
25cc weed eater, will only idle
I have a 25 cc weed eater that will only idle I can only get it to start on full choke, imediatly have to switch it to half choke to keep it running. if I give it any throttle at all it quits. I have put in a new sparke plug, run new fuel lines, mixed new gas. The compression is 90 psi and the exhaust is not plugged. The carb only has an ajustment for the idle. Please help
  • Anonymous Mar 25, 2014
    Hard to idle and does when moving switch to open
    Problem Solver:
  • 7 Answers
Double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ prerunnerrngr@yahoo.com and i will point them out
Posted on Jul 14, 2009
  • 130 Answers
I have found out over 25 years fixing small engine carb are lot of the problems.rebuild the carb and clean real good blow out real good it will go back working fine the diapham go bad.allso change fuel filter to put new gasket between carb and block.let me know if this help you.please.
Posted on Jul 25, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why will My weed eater only run with the choke fully on and cant give throttle?
    It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
    May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    No spark on Weed Eater FB25 25cc Gas Blower
    Test the kill switch first, disconnect the kill switch and see if you have spark. Then the kill switch is not working or is grounding out. If not, the problem could be the ignition module.
    Mar 16, 2013 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
    New poulan pro 25cc chokes out after if I give it full throttle. Runs ok except it wont stay running on full throtle.
    I find with my Poulan Pro that you need to let it warm-up abit before applying full throttle, I live in Upstate NY where the weather has bee great lately,however, it stalls easy ..I mix 1-pint of 3 stroke oil to 1-gallon of gas for my weed eater and have no problem
    Nov 05, 2011 | Poulan 25CC Gas BlowerVac
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    I need to know the gas to oil ratio on my 17" 25 cc craftsman weed eater.
    4 oz of a generic 2-cycle oil to a gallon of fuel is the typical mix.
    I hope this helps.
    Jun 17, 2010 | Craftsman 25cc Gas Line Trimmer
    Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
    1,057 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
