Samsung bd e8300
It works perfectly, but it keeps switching itself off at random,I tried a reset but that didn't work.
  • 11 Answers
SOURCE: HDMI - no output Samsung P1600 BD
the hdmi output generally needs activating through the menu system. im assuming you havent already done this.
connect it with whatever cable works and navigate through to the menu system to select the hdmi output.
failing that it might be the hdmi cable is an older cable not capable of supporting ver1.3
Posted on Feb 07, 2010
  • 17 Answers
SOURCE: my 42 inch samsung plasma
You have bad caps on the SMPS. Either replace the caps or replace the SMPS
Posted on Sep 09, 2010
SOURCE: have a samsung plasma that keeps switching itself
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Samsung, in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Posted on Dec 13, 2010
bronk50
  • 27725 Answers
SOURCE: Samsung BD-E8300 HDD not detected
If using windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Jul 31, 2012
Geekman
  • 32281 Answers
SOURCE: how to make samsung bd-e8300 multi region
You maybe able to get a region free code for your player from one of these WEB sites. www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm http://www.dvddemystifiziert.de/codefree_en/codefree.html
Posted on Mar 19, 2013
My Samsung HT-E5400 home theater changes source by itself.
i have the same problem and is so frustrating, it skips all sources with a loop that never ends. any fixes yet?
Jan 13, 2013 | Samsung Ht-e5400 5.1 3d Ready Blu-ray Home...
Stuck on load screen
I upgraded the unit on Dec. 24th and I now have the same problem. My solution is to take it to your local recycling plant and don't buy another Samsung player. I contacted support and because the unit is out of warranty they can't (will not) do anything. I tried reapplying the firmware via the USB and it didn't work. Anyone have a way to reset the firmware to the factory version?
Dec 24, 2011 | Samsung BD-P1500 Blu-Ray Player
Harman Kardon AVR7550 turns itself off.
check to see if there is a reset switch inside on transformer bd. could be dirty. clean with contact cleaner.
Nov 26, 2011 | Harman Kardon Audio Players & Recorders
I have a problem with my Samsung BD C5900 blu ray player. When I try to activate the internet @ TV function it will not open the internet page. It instead tries to load a new firmware. A icon appears...
I have just installed the BD C5900 and have exactly the same problem. Spoke to Samsung and they say your have to switch the blu-ray off and on the front of the blu-ray player itself press and hold the stop button for approx 30 seconds (small square symbol). This is a master reset. You then follow the set-up procedure as you did when you first installed the blu-ray. I did this and mine works fine now and has the latest software version BSP-C5900WWB-1009.1 installed okay now, and everything including internet accessable once again..
Jan 26, 2011 | Samsung BD-C5900 Blu-ray 3D Player
Bd c5900 + Samsung PS50C680 tv trying to turn itself on. When I try to select internet@tv it stays on installing, the icon next to it keeps rotating but it goes nowhere even after 3 hours. If I try this...
When this happens you need to perform a hard reset of the Blu-ray player, i.e. turn it off then on at the wall.
You should then be able to access internet@tv once the Blu-ray player has been reset.
Unfortunately this seems to happen quite regularly - I guess we need to wait for another firmware update to provide a proper fix!
Jan 02, 2011 | Televison & Video
Feb 07, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Seemed to short circuited through power surge from
You have a bad Main bd. Have a trained Samsung tech repolace the Main bd.
Jul 02, 2009 | Samsung LN-T4671F 46 in. LCD Television
Samsung 40" LCD LE40R74BDX screen flickering all different colour
You either have bad Main bd and or a bad T-Con bd on the Panel. Have a trained samsung tech troubleshoot the set.
Jun 30, 2009 | Samsung LE40R74BDX 40 in. LCD Television
320 people viewed this question
 Grubhead
Grubhead
