Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Magnavox -Phillips -55 inch projection tv -model 55P8241 - can not move blue convergence enough . Two weks ago I changed the coolant for a cloudly picture , put it back together and it worked great . Over the last 2 weeks the blue convergance started shifting to the right of the screen. When I try and move the blue over , it will not go into the cross hair . The multi point is even worse . I pulled the back cover , checked for leaks and loose wires , but looks fine . Any sugestions ?
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
You may have bumped the alignment rings on the bottom of the tubes. Either that or the convergence chips are bad.
Posted on Aug 09, 2009
Philips magnavox 55" rear projection tv problems
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 11, 2010 | Philips Magnavox 9P6034C 60" Rear...
Where can i find a new key bord part #313501707611 its for a phillips model # 60p8341
Try http://www.encompass.com They have the best selection of parts at the best price. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 18, 2010 | Philips 55P8241 55" Rear Projection...
Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Changing oil, in guns RED Green Blue ( algae)
you can get the coolant kit which has the coolant for all three tubes and step by step instructions on how to do the proceedure on the phillips / Magnavox rear projection Tvs.Heres the link shipping is free within the US.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 22, 2009 | Televison & Video
55" Phillips Projection needs coolant changed
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 02, 2009 | Philips 55P8341 55" Rear Projection...
Red "aura" in the middle of my 55" Phillips Magnavox
Your TV most likely has one or more possible problems.
  • Screen looks 3D
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
My 60inc phillips magnovox has poor color, what do i have to do?
we just bought a 55 inch phillips magnavox and told it was working fine when we got it home and turned it on it was a red screen and was really foggy. we looked up some tv repair places and ONLY 1 told us it was the picture tube and to look down them with a flashlight for bacteria! sure enough the green and blue had it. so we found one place that would sell us the coolant fluid that you have to change the others could get it in or wanted us to bring the tv to them. we did it our selves the stuff was $17.00 a bottle or if we took it in it would be about $375.00. we have a great picture now and it wasn't as hard as all the other repair places said.
Dec 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
684 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
