Question about Boating
Dies in reverse and runs great chocked
I have a 1982 35 hp Evinrude that has very low hours and all of a sudden this season it wants to die when shifted into reverse and the top end is gone too. Fresh gas and oil ,winterized every year since new. I would have to say there are maybe only 80 hours total on this outboard. Had it out tonight and it runs fine when choked, but stumbles when I unchoke it. Any help where to start????????????????
  • Rick Rife
    Rick Rife Jul 15, 2009
    Thank you for the help Finish Line. I cleaned out the lines,fittings and rebuilt the carb just to be safe.But I forgot the plugs and will do exactly that in the morning and will let you know how it went.
  • Rick Rife
    Rick Rife Mar 09, 2010
    engine runs fine in tank but not underload. Coils seem to check out, any other ideas
    Champion:
  • 207 Answers
FIRST CHANE THE PLUGS DONT CLEAN CHANGE
Posted on Jul 13, 2009
1983 9.9 evinrude runs good on land but will not accelerate under load.
This happened to mine, I found out the gas lines were going bad and restricting the flow of gas
Apr 02, 2017 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
1976 evinrude 85 hp
have you checked the carbs are clean and balanced and fuel pump diaphrams ok ? compressions 100psi or more ? possible bottom crank seal and this wont show up on compression test ! because of the age i would change both seals as they go hard !
Sep 20, 2013 | Boating
My 7hp tecumseh engine on an ariens tiller will run great until the engine gets really warm. Then it will die. I will restart it immediately and it will run for about 30 seconds and die again. Ive...
A few possibilities to check:
1. The chock is stuck on. Pull the air cleaner while running and see if the chock is closing off part of the throttle.
2. Check the OHV valve settings, could be the tolerance is too tight.
May 27, 2011 | Garden
For some reason my husqvarna yth22v42 lawn tractor will run for a short period then suddenly stalls and dies out. at first i was thinking maybe the fuel filter needed changing so i changed it, while i was...
if it sputters then dies its your fuel system,if it dies completely its the electronic pickup or ignition module thats doing it,if you can heat the flywheel area carefully,it may do it for you after time and guide you to which problem it is
Mar 04, 2011 | Husqvarna YTH22V42 22HP Lawn Tractor 960...
Runs for a second then dies , just smoged and passed then next day trouble when trying to start fires up runs like its over chocked then dies , new cap rotor fuel filter , seams like it happed right after...
Fuel pressure regulator diaphragm may have split. Remove the cover plate on the throttle body and inspect the diaphagm for damage. See part 2 at link below. The tbi pics are around the middle of the page.
Do It Yourself Diagnosis and Repair
Sep 13, 2017 | 1989 Geo Tracker
My unit has been running great up till now. Just
Check compressor for high current consumption.Check capacitors. Check fan speed.
If fan speed is low compressor will over heat and trip safety circuit in the compressor. If there are independent fans check both of them.
May 26, 2010 | Mitsubishi MS-A12WA Air Conditioner
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
Dies when placed in drive , other wise,runs fine, will not die if foot held on acclerator slightly.does not die in reverse
u need an idle air control valve, they go bad alot on fords when the temperature changes between seasons
Nov 24, 2009 | 2000 Ford Crown Victoria
Boating Logo
197 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
