Question about Hayward 1.5 Hp Northstar High Performance Pump
Pump motor runs very shot time turns on and off continuously
Motor set up by distributor for 220 when delivered pool supplier advised to connect two of the three wires foe 110. Now pump motor will not run for any period of time and shuts off. Please suggest resolution to problem. Motor is two speed and on 110 will only operate at low speed.
    President:
  • 1,723 Answers
You have to go by the name plate connection for correct voltage and two speed operation. Check name plate and verify incoming voltage. Connect motor accordingly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 13, 2009
How to wire a intermatic pe153 neutral and ground wire. I only see a lug for the hot wire. Where does a neutral and a ground connected to the pe153 timer?
Neutral is common to the neutral motor terminal. The hot wire (line) goes to the other motor (timer) terminal. Your pump is connected to the "Load" terminal.
If your motor is running on 220 ... you will need a 220 timer switch and there will be two 'load' and two 'line' terminals. In the case of 220 ...there is no neutral. Ground goes to the case ... if it is metal. Otherwise, just continue the ground to the motor ... You will also of course, have to bind the motor using the bond terminal to connect to the pool bonding system.
Oct 18, 2011 | Intermatic Digital Time Clock In Metal...
I am installing a new pump and motor. the motor is 110/220 optional. I am 220. The connectors are A, B, L1 and L2. What goes where for 220. Thanks
There is always a wiring diagram on the side of the motor. If you want help with this one still, you would have to list here the exact model of pump, and the model of the motor connected to it.
Most common connections are to run one hot line to L1 and one hot line to L2.
You would want to confirm this on the motor housing though as some motors are different than others.
Nov 13, 2010 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Pool pump turns off after 1/2 hour or so but I can turn on manually after it sits for a while. Timer is working fine. Hayward Super II around 5 yrs old. Do I need to replace this motor? This problem just...
Your pump is protected by a thermal device that shuts it off when over heated. Are you running 110 or 220? In my experience, your pump will run cooler on 220 ... consider coverting if appropriate.
Aug 28, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
How to install hayward motor?
Just the motor? Three things you must consider: There are 4 bolts that fasten the motor to the pump housing. You need to determine 110 Volts or 220 volts - 220 will run the pump more efficiently. Bonding. Your motor must be bonded to all other metal parts of your pool system.
Aug 22, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Need to connect 220 pool motor to timer
You will need a double pole intermatic or similar switch. You actually want to control the plug where you plug your pump into, not the motor directly. The timer will probably run on 110 but may be a 220 clock. Ask where you purchase the device.
Jul 26, 2010 | Pentair 1.0 Hp Whisperflo Pump
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
Hello i hooked up a t104 timer to a 220 pool pump i have 3 wires going to timer 2 hots and a ground the pump works correctly when timer is switched to manual but timer does not work can you please advise...
I assume it's an Intermatic T104. I believe this has a 230V motor, which is best for your application. Since you only have 2 hots and a ground I assume you're only switching one leg to the motor. That's why the timer won't run. It need 240V to run the motor. You need 5 wires. Two "hots" coming in, and two going out to the motor along with your equipment grounding conductior (green). This will disconnet all power to the pump when off. Pay attention that you put the two incoming leads on correct terminals which I believe is #1 and #3. That's because those terminals also power the clock. Then connect the motor to #2 and #4 which go to the motor. 1 closes to 2 and 3 closes to 4. The equipment grounding conductor connects to the GR terminal (Green)
Jun 30, 2010 | Hardware & Accessories
How do you get the SP3015X20AZ set up for 115v use? How do I hook it up? Thank you Rita
You will have to change the power on your breaker ... take the white off and put it to the neutral bus. This will change the power beig delivered to the pump. In the motor, remove the white wire and put it on L1 ... black should already be on L1.
A side note ... 220 runs more efficiently and your motor will run cooler and at less expense. I suggest you not change it unless there is good reason.
Jun 04, 2010 | Hayward SP3015X20AZ 2 HP SUPER PUMP II ...
Wirng connecions for 110v pentair pool motor???
There shopuld be a diagram on the nameplate of the motor, or on the cover for the wiring compartment, or there is some stamped indication at the wiring lugs that tell you where to put your feed and what position the internal wires are to be in or the jumper .. for 110 volts or 220 volts.
May 29, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Hayward 1.5 Hp Northstar High Performance Pump Logo
144 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
