Question about RCA HD52W59 HDTV Projection Television
Where is the convergence on the rca menu screen
  • RCA Master
  • 8,617 Answers
Its under the settings option. If its missing you will need the RCA ITC222 convergence option missing repair kit available at the following link. The kit has the replacement parts and the CD with instructions on the repair.
http://www.tvrepairworld.com/
Posted on Jul 13, 2009
  • 147 Answers
SOURCE: 3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
Posted on May 26, 2009
  • 25 Answers
SOURCE: rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Posted on Aug 29, 2009
Slinteriors
  • 8617 Answers
SOURCE: how get auto convergence on RCA HD52W59YX38 to appear on screen
you can get the repair kit for your RCA at the following link. Its called the ITC222 and ITC222A convergence option missing repair kit, comes with detailed instructions. www.tvrepairworld.com
Posted on Sep 04, 2009
  • 1779 Answers
SOURCE: I have a 3 or
You'll have to remove the deflection board on the left and re-solder all pins on the IFT then check the 3 brown fuses to the right of it. You should be good to go after that.
Posted on Dec 18, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Convergence Menu
If the converegence circuit has failed it wont show up till you fix the TV.
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Posted on May 11, 2010
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Cant find convergence on menu screen
The HD61LPW42 is a RCA DLP which doesnt have convergence. If the convergence is out of alignment you have a three CRT TV such as the D52W19, HD52W59 RCA Check the model number from the rear tag and let me know what the model number is.
Nov 21, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Rca p56926 screen is concave and cant adjust convergence in menu
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
Aug 04, 2009 | RCA P52771AT 52" Rear Projection...
May 26, 2009 | RCA R56WH76 Projection Television
RCA HDTV
go into the menu
looking for set up tab
looking for convergence tab
looking for automatic convergence. apply.
Fixed. NO? tv has a problem in the convergence area. Technican Job
Apr 08, 2009 | RCA R52WM24 52" HDTV Projection Television
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Help! Menu options missing!
half a year and still no answers, this site is lame....
May 20, 2007 | RCA P61927 61" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
246 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
