Question about NetGear RangeMax WPN824 Router
Netgear 824, security = intermittent WiFi connectivity
I'm not able to set the security at any level on the Netgear 824 and get dependable WiFi connectivity. I was able to get the WiFi working quickly WITHOUT security (eeek!).
With security enabled, using WiFi, it's just one connection issue after another... relink relink relink
I've powered EVERYTHING up and down numerous times, pushed the router reset, and fiddled ignorantly with settings on the Netgear routerlogin.net site to no avail.
What's next?
I'm a PC, fwiw.
  • tortolitas1 Jul 13, 2009
    So far somewhat helpful...
    I get to step 3.c. "Set it to Use computer MAC address and click on the apply button"
    At this point my connection to the internet becomes non existent.
    Looking ahead I have a question (I tried a quick search which did not provide a simple obvious answer)
    I am a subscriber to Cox Cable and hive my internet connection through them (DSL or something like that right?)
    You ask me to enter my ISP's username (usenrame@ISPdomain)and password... would that be like "cox@ispdomain" ? or is that Me@cox.net amd MY password my brain is not as sharp any more.
    also WEP is only one of the options and supposedly less secure... Why WEP? best chance of success? son's hypothesis is that a security setting is confounding the otherwise successful installation.
    DOES my PRIMARY PC have to be hooked up direct at all times or can I take it onto wireless after setting up?
    Thanks...
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 13, 2009
Netgear wifi vs moto x phone
Step 1
hey can you login to your router of yes make sure your router is dhcp enabled, then on you phone kindly delete or forget your current wifi settings, then do a phone restart and register a wifi (connect to a new wifi spot) and try again.
Step 2
    If the page displays, you have Internet access. If the page does not display in a minute, see the "No Internet With New Router, Computer or Adapter: MAC Spoofing" article.
  2. Determine if the modem's IP address can be seen.
    In the router interface, go to the Status Page. For more information, see your router user manual.
    If the modem's IP address cannot be seen, reboot the modem, router, and computer, in that order. Be sure to wait for each device to completely reboot before rebooting the next.
    If the modem's IP address is seen, and you stuill cannot access the Internet, you might have a problem with your browser's settings. Your security might be set too high for the Internet service you are trying to use, or your browser might be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to High, change it to Medium. Click Tools > Internet Options > Connections. If the radio buttons in the center are not dimmed, settings for a dial-up connection are being used.
Mar 14, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
Cant connect the wifi
to configure the netgear router. . . . 1, first make sure that your laptop is connected directly to the netgear router via ethernet cable. 2. after securing step 1, on your computer, open browser, ( internet explorer or firefox ) 3. go to the address bar, the one with the http:\\ and erase everything inside it. 4. type in there, 192.168.1.1 or www.routerlogin.net. 5. username is " admin " password is " password " 6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard. 8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key 9. the network security key is the " passphrase " then click apply. then your all set for wireless connectivity.
Aug 28, 2011 | NetGear WGR614 Wireless Router
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Feb 23, 2011 | D-Link Computers & Internet
I don't know how to connect my second laptop to the netgear router to get internet service.
Go to the first pc that is already connected. Right click your connection and note the status/advanced information, find the gateway IP address. Open a web browser and login to your netgear router. NetGear default is admin and password.
Now go to the wireless setup, note the ssid or name of your wifi network, also note the security encryption and phrase you are using. If you don't remember you can set it again there and save but then you will need to reconnect to it, if all else fails use a data cable and plug directly up to the router to manage it.
Once you know your wifi name and security key you setup, go to pc 2 and use the wireless utility scan or refresh you should see the name of your wifi network, click join to connect, it will challange you for the password. It if doesn't then all of your neighbors can use your internet and access your computers. Need to be sure to secure your wifi signal by managing it via the web management using your web browser.
Aug 29, 2010 | NetGear WGR614 Wireless Router
Trying to connect to home wifi with netgear router and EEpc G2g
Chekc your security settings, it can be that Eeepc not correctly determine security settings. Try to set all security for your SSID manually.
Apr 19, 2010 | ASUS Eee PC 2G Surf Notebook
I have a Netgear router -but I dont have the same computer that I used to set up Internet connection. My router works but is not secure
the computer you have should make no difference to how the router works.
If your wifi connection is insecure you will need to login to it and add the security under the advanced/wireless (wifi) options and add a password.
if you connect to the router with a cable then just turn off (disable) the wifi, you don't need to set up the security.
Jan 04, 2010 | NetGear WGR614 Wireless Router
My netgear rangemax does not emit a steady wifi signal. if i plug in my computer, the internet is working fine. all of the lights are on on the router. The wifi network shows up for a few minutes, goes...
Intermittent wireless connection can be caused by different factors, such as:
1. Wireless interference within the network. For best results, place your router:
- near the center of the area in which your computers will operate.
- in an elevated location such as a high shelf where the wirelessly connected computers have line-of-sight access (even if through walls).
- away from sources of interference, such as microwaves, and 2.4 GHz cordless phones.
- away from large metal surfaces.
2. Wireless settings on the router are still set to default. This may cause conflict with other Netgear routers within your network range.
- change the router's SSID or wireless network name.
- change the router's channel.
- enable wireless security on the router.
3. If the wireless connection is still unstable after performing the steps above, it is possible that the firmware is corrupted. Upgrade the router's firmware.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Had my netgear router for months now and not had a
Solution to intermittent wireless connection is change the wireless channel of the router. Usually the default channel is 6 which is prone to interference. You may try channels 11 and 1. They are the next strongest channel of the router. Try to reset the router first.
Jun 06, 2009 | NetGear DG834G Router
Get Netgear 824 wifi working for all computers
I just got my Netgear 824 and I was able to connect to it with my pc and my wifi enabled phone but not with my ibook. Solution: when entering the WEP password enter a $, dollar sign, before the WEP password. I tried it and it worked like a charm.
Mar 09, 2009 | NetGear RangeMax WPN824 Router
Can't set up security for Netgear 824
LOL you bought it, you get to figure out how it works.
I used a MAC for a day, and the owner had to tell me how everything works. If you can get to the internet, I imagine you can go to www.routerlogin.com and get access to the Netgear. The Wireless Settings tab on my Netgear brings up text sensitive help on making security and wireless work.
Carl
NetGear RangeMax WPN824 Router Logo
476 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
