Question about Proscan PS35690 TV
I have a proscan tv (PS35690) that when i turn the power on the power light flashes 3 times
2 Suggested Answers
vcrdr1
  • 53 Answers
SOURCE: My tv won't turn on
you probably have a bad flyback transformer and horizontal output transistor. i would take it to your local repair shop.
Posted on Jun 11, 2006
My proscan TV was working fine. then the video went and now no audio.. it lights up briefly when u turn on. then screen goes dark.. is this fixable or better to get a new tv..It is only 3 years old
I believe it's fixable! Take a look on your video and audio cables (behind the TV, the red, yellow and white ones). They must have a problem. Already happened to me!
I hope I've helped...
Feb 14, 2011 | Proscan 42LA45H 42 in. LCD TV
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
I JUST GOT HOME AN TRIED TO TURN MY JVC PLASMA TV ON. THE TV WILL NOT TURN ON. EVERYTHING ELSE HAS POWER TO INCLUDE THE TV BUT THERE IS NO PICTURE OR SOUND. BLANK SCREEN. THE BLUE POWER LIGHT IS FLASHING ON AND OFF. THE MODEL NUMBER LT-42P789
Jul 16, 2009 | Proscan 19LA25Q 19 in. LCD Television
Program Directv remote to operate the Proscan TV
The Proscan is an RCA product so the codes are:
10047, 10466, 11347, 11447, 10018, 10019, 10038, 10047, 1090, 1135, 10679, 11047, 11147, 11247, 11347, 11447, 11547
1. Turn on the TV
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under TV flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of TV being set up. If performed correctly, the green light under the selected position lashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
If this helps please rate my response. Have a wonderful day!!
Jun 27, 2009 | Proscan Televison & Video
Need codes for proscan to put in direct tv remote
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
May 06, 2009 | Proscan 32LA30Q Television
Proscan ps32600
PRESS AND HOLD THE POWER BUTTON UNTILL THE LIGHT CHANGES AND TV WILL COME ON
Jan 17, 2009 | Proscan PS32600 32" TV
Hi my name is lily i have a ploblem with my tv is proscan 19inchla25q i try to turn it on but it wont go on the red ligt flashes gree then it turn back on in red
The power supply is bad. It supplies enough power to light the red LED when the tv is powered off, but not enough to power up the tv. You can find one on ebay.
Jan 08, 2009 | Proscan 19LA25Q 19 in. LCD Television
Proscan tv 36in
Many problems with this unit with the HV transformer (flyback) and also a regulator ic in the power supply. Sorry, nothing easy for this type of problem. You will need a tech to diag. and repair this problem.
Mar 01, 2008 | Proscan PS35660 TV
Proscan TV powerup
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Dec 17, 2007 | Proscan PS35660 TV
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
My tv won't turn on
Jun 11, 2006 | Proscan PS36600 36" TV
Televison & Video Logo
74 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
