Question about Pro-Fit Pro.Fit Fo 71 02 Ford Explorer/Mercury Mountaineer Sable
1998 Ford Explorer. Won't start, just clicks, with new battery.
I bought a used 1998 Ford Explorer two days ago. While checking the vehicle out before I left, I shut the engine off, so the oil could be checked and topped off, if needed. The Explorer wouldn't start without a boost. The dealer said that I should have a full charge within fifteen minutes. An hour later, when I got home from the purchase, I parked it. When I tried to start it, last night, it wouldn't start, so I bought a battery today. It still will not start, not even crank over, it just clicks. The lights and radio work fine. What is the problem? Help!
    President:
  • Pro-Fit Master
  • 1,348 Answers
Check that the cabling going to the starter is ok. and the ground to the frame and the engine block.the other thing is that it is possible the starter has a "dead spot" in it.have someone turn the key to start and bang on the starter with a hammer .not too hard.the starter on ford starters usually have a solenoid and it is possible that is no good either...
cheers ed
Posted on Jul 13, 2009
2004 Ford Explorer won't start if I let it sit for a a few days. I turn the key and it just clicks but will start with a boost. I have had the battery and starter checked and the mechanic couldn&#
Why didn't the mechanic continue on & resolve the issue?
You don't have the experience to do so, as your here
No one can tell you what is wrong without the vehicle to test,
common sense
Feb 07, 2013 | 2004 Ford Explorer
1998 Ford Ranger won't start.
Check the igntion signal to the starter solenoid.
Oct 10, 2012 | 1998 Ford Ranger
My 93 ford explorer sport started to click then slow down and now it won't start up what could be the problem
sounds like the battery is dead. Try recharging the battery or try jump starting from another vehicle using jumper cables.
Apr 30, 2012 | 2001 Ford Explorer Sport
When I shut off the motor sometimes it wont start. I just bought a new battery 2 months ago. When I turn the ignition the starter doesnt even make a clicking sound. I can jump it or let it sit a couple of...
It might be your anti-theft alarm system. When the car doesn't start, is there a ticking sound inside the car? If so, hit the unlock button a few times on your keyless entry remote, until the ticking stops, then try to start the car. Hopefully this helps.
Mar 27, 2010 | 1998 Ford Explorer
Battery goes flat frequently after 5 days not used. Ford say that it is because of electrical componentry runnign all the time and you have to expect this. Is this so? I have put in a new gel battery and...
Why are you using a gel battery?? you shuld only be using a starting battery. Gel batteries, when weather gets really cold, will die out and cannot be recharged. They are not like a typical starting battery made for the vehicles large drain when starting.
Dec 14, 2009 | 1998 Ford Explorer
1998 ford explorer eddie b, key will turn car won't start
Check to see if the battery cables are tight. Or, check to see if your terminals might have some corrosion around them. If it's not either, than it might be the battery needing to be replaced. And, if that isn't it, try your local auto shop and ask them.
Aug 30, 2009 | 1998 Ford Explorer
1998 Ford Explorer XLT 4.0L W/Air
Return the battery and get another, sometimes because the battery set there too long and won’t work, I had twice when I had my Union 76 Station, after you try it, if you still can not start your son’s car. Let discuss more.
Jul 06, 2008 | 1998 Ford Explorer
1998 Ford explorer transmission 4.0 L OHV Engine
Yes 1 more thing is here for you that can be don by you for activating you car on road,
1.check you battery have a suficiant voltages,
2.check your spark ignition kit,
THNX
May 17, 2008 | 1998 Ford Explorer
Pro-Fit Pro.Fit Fo 71 02 Ford Explorer/Mercury Mountaineer Sable Logo
790 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
steve morris
steve morris
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
