LED flashes 5 times but wont power. You can hear it clicking. Is it safe for me to just replace both the X, and Y boards since im an amatuer? I can get a good used board each and would that fix me up?
SOURCE: Samsung PS42C7S Power Board
A blinking led does point to a bad power supply board! First, Look for some bad caps (capacitors) on the board. They will look bulged on the
top an may be a little leaky (brownish stain).
You should be able to find a service manual @ www.manualzone.com
Buying a power board try www.shopjimmy.com or ebay!
Good luck, hope this is helpful!!!
SOURCE: my samsung plasma tv went out and it just makes a
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
SOURCE: I have Samsung spn2435 plasma T.V. that when you
The ysus board is the most common reason.you have to replace the board, you can check on shopjimmy.com, ebay.com for replacement.Thanks and Take care
SOURCE: Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: I was given this Samsung LED TV after it had been
submit this symptom on you tube you,ll be amazed what you might find it has helped me many many times.use model number especially and you can get parts on shopjimmy
