Question about Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red
4 whhel strider won't run, batteries charged
Batteries show a full charge with ohmeter. Turn the key, green light blinks, horn works but won't run. Indicator doesn't move out of the red.
Last time it was used, it lost charge quickly, but that was before recharging batteries.
  • Anonymous Mar 20, 2014
    The scooter runs fine then slows down the green light blinks twice indicating low battery then it takes off and runs fine with no light blinking.
The motor is not working perfectly and chnge motor or check the connection perfctly
Posted on Jul 14, 2009
Mobility scooter green light blinks twice and wont go.
If you have a CTM UNIT, with Dynamic Modular, then you have batteries not holding charge. If this happens only when ur using your product, then batteries will be the issues.
CTM 909-590-1388 x115
Aug 31, 2016 | Electric Strider Maxi 4 Wheel Mobility...
Batteries for strider full, but wont move brake appears to be on.
Hi how did u test the batteries.the only accurate way to test them is to use a BATTERY load tester ...u can buy them on E/BAY.APROX COST $35::.cheers
Jul 05, 2016 | Electric Strider Midi 4 Wheel Mobility...
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the...
soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Mar 25, 2011 | Drive Medical Odyssey Full Size Scooter
Battery is charged, scooter is assembled, but when the key is turned on, the scooter and all gauges are dead
Has the scooter been sitting unused for a while? Will the horn honk when the scooter is connected to the charger?
If the batteries are charged and NO LIGHTS come on at all when you turn the scooter on, please check all of your connections, most importantly the fuses as your circuit may be incomplete.
If there was any power getting to the scooter at all, the lights would at least blink to let you know there was a problem.
When batteries sit for a while they will oxidize and go solid which may prevent them from getting a full charge. The charger shows them as full but it is just the current bouncing back from the solid core. Try replacing the batteries to see if that solves the problem, if not, contact the manufacturer.
Dec 18, 2010 | Health & Beauty
Replaced batterys worked fine forabout 1hr. then speed went up fast then nothing. lights and horn work , batterys are charged. no response to forward or reverse controls
Unfortunatly, your batteries need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own. There is enough power to turn on the lights and honk the horn, but not enough to get the motors to work.
Oct 23, 2010 | Electric Mobility Mobility Electric Power...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red Logo
648 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
